Hello again,
Has anyone had any experience in extracting feature catalogues using iso
19110 that contain a unique list of values for the attribute columns?
*type* (String)
List of valuesNameCodeDefinition
Regards
Dean
Hello again,
*type* (String)
Regards
Dean
2015-06-10 10:08 GMT+02:00 Dean Howell <deanhowell2009@anonymised.com>:
Hello again,
Not sure about what you mean, but a sample here with an attribute column
allowing 1,2,3,4,5 as values and the corresponding name and definition :
http://sdi.eea.europa.eu/catalogue/srv/eng/catalog.search#/metadata/411cd05b-9a79-45f2-b39f-0b344a9f35af
Francois
*type* (String)
RegardsDean
GeoNetwork-users mailing list
Here is an example record that I have that may be of some use.
Jacqueline Mize
Metadata Specialist
Riverside Technology, Inc.
NOAA National Centers for Environmental Information
1021 Balch BLVD, Suite 1002
Stennis Space Center, MS 39529
email: Jacqueline.Mize@anonymised.com
ph: 228.688.2174
On Wed, Jun 10, 2015 at 7:18 AM, Francois Prunayre <fx.prunayre@anonymised.com>
wrote:
> Hello again,
allowing 1,2,3,4,5 as values and the corresponding name and definition :Francois
> *type* (String)
> Regards
> Dean
Jacqueline Mize
Metadata Specialist
ph: 228.688.2174
featureCat.xml (339 KB)
Thanks Jacqueline and Francois,
Yes that is exactly what I am trying to achieve but wanted to see if there
was a way to automate the population of the list or is it a manual task?
Regards
Dean
On Thu, Jun 11, 2015 at 3:58 AM Jacqueline Mize - NOAA Affiliate <
Jacqueline Mize
Metadata Specialist
ph: 228.688.2174On Wed, Jun 10, 2015 at 7:18 AM, Francois Prunayre <fx.prunayre@anonymised.com>
wrote:Hi,
> Hello again,
> *type* (String)
> Regards
> Dean
http://sourceforge.net/projects/geonetwork--
Jacqueline Mize
Metadata Specialist
ph: 228.688.2174
2015-06-10 23:16 GMT+02:00 Dean Howell <deanhowell2009@anonymised.com>:
Depends on what you have. You may have UML diagrams or XSD which may
contains list of values for attributes ? Some time ago we made an ISO19110
QGIS plugin (https://taskman.eionet.europa.eu/issues/70) for helping
analyzing the content of the attributes and populating an ISO19110 records
which could be finalized manually and then loaded in a catalogue (not sure
if it still work with recent QGIS version ?).
At some point, you always have to populate the details manually.
Francois
Regards
Dean
jacqueline.mize@anonymised.com> wrote:Here is an example record that I have that may be of some use.
Jacqueline Mize
Metadata Specialist
> wrote:Hi,
> Hello again,
iso
> *type* (String)
> Regards
> Dean
Jacqueline Mize
Metadata Specialist
ph: 228.688.2174
Dean,
If all more most of the information is stored in a database or spreadsheet
already then you could build an XSLT to auto populate the 19110.
http://www.ncddc.noaa.gov/metadata-standards/metadata-xml/
http://service.ncddc.noaa.gov/rdn/www/metadata-standards/metadata-xml/documents/Automated-Metadata-Generation-Using-XML.pdf
Jaci
On Thu, Jun 11, 2015 at 5:38 AM, Francois Prunayre <fx.prunayre@anonymised.com>
there was a way to automate the population of the list or is it a manual
task?Depends on what you have. You may have UML diagrams or XSD which may
if it still work with recent QGIS version ?).At some point, you always have to populate the details manually.
Francois
Regards
Dean
Jacqueline Mize
Metadata Specialist
fx.prunayre@anonymised.com> wrote:Hi,
> Hello again,
iso
> *type* (String)
> Regards
> Dean
Jacqueline Mize
Metadata Specialist
ph: 228.688.2174
Jacqueline Mize
Metadata Specialist
ph: 228.688.2174
