I have some problems using the feedback form at the 'contact us' site.
I put all the parameter for host, port etc. at the system configuration, but when I try to send a feedback this error was been generated.
Does anyone has any experiences getting access to a mailserver with GN? I do not understand the exceptions.
Thanks.
Christian
2008-01-24 16:30:21,639 INFO [jeeves.request] - HTML Request (from 141.65.4.192) : /geonetwork/srv/en/feedback.insert
2008-01-24 16:30:21,639 DEBUG [jeeves.request] - Method : POST
2008-01-24 16:30:21,640 DEBUG [jeeves.request] - Content type : application/x-www-form-urlencoded
2008-01-24 16:30:21,640 DEBUG [jeeves.request] - Accept : text/xml,application/xml,application/xhtml+xml,text/html;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5
2008-01-24 16:30:21,640 INFO [jeeves.service] - Dispatching : feedback.insert
2008-01-24 16:30:21,640 DEBUG [jeeves.service] - -> parameters are :
<request>
<id />
<email>h.holmersson@anonymised.com</email>
<name>Holger Holmersson</name>
<org>UFZ / SUV</org>
<comments>Let's try to send a feedback.</comments>
<fname />
</request>
2008-01-24 16:30:21,640 ERROR [jeeves.service] - Exception when executing service
2008-01-24 16:30:21,640 ERROR [jeeves.service] - (C) Exc : java.lang.NumberFormatException: null
2008-01-24 16:30:21,641 DEBUG [jeeves.service] - Raised exception while executing service
<error id="error">
<message>null</message>
<class>NumberFormatException</class>
<stack>
<at class="java\.lang\.Integer" file="Integer\.java" line="415" method="parseInt" />
<at class="java\.lang\.Integer" file="Integer\.java" line="497" method="parseInt" />
<at class="org\.fao\.geonet\.services\.feedback\.Insert" file="Insert\.java" line="74" method="exec" />
<at class="jeeves\.server\.dispatchers\.ServiceInfo" file="ServiceInfo\.java" line="238" method="execService" />
<at class="jeeves\.server\.dispatchers\.ServiceInfo" file="ServiceInfo\.java" line="141" method="execServices" />
<at class="jeeves\.server\.dispatchers\.ServiceManager" file="ServiceManager\.java" line="372" method="dispatch" />
<at class="jeeves\.server\.JeevesEngine" file="JeevesEngine\.java" line="600" method="dispatch" />
<at class="jeeves\.server\.sources\.http\.JeevesServlet" file="JeevesServlet\.java" line="163" method="execute" />
<at class="jeeves\.server\.sources\.http\.JeevesServlet" file="JeevesServlet\.java" line="98" method="doPost" />
<at class="javax\.servlet\.http\.HttpServlet" file="HttpServlet\.java" line="616" method="service" />
</stack>
<request>
<language>en</language>
<service>feedback\.insert</service>
</request>
</error>
2008-01-24 16:30:21,641 INFO [jeeves.service] - -> dispatching to error for : feedback.insert
2008-01-24 16:30:21,778 INFO [jeeves.service] - -> transforming with stylesheet : /home/cgadge/geonetwork_2.1.0/web/geonetwork/xsl/error.xsl
2008-01-24 16:30:21,849 INFO [jeeves.service] - -> end error transformation for : feedback.insert
2008-01-24 16:30:21,850 INFO [jeeves.service] - -> error ended for : feedback.insert
