[GeoNetwork-users] FGDC to ISO transforms
Dear Jaci,
Thank you very much for regenerating the above transforms for XPath 1.0. I've tried to wire this into Geonetwork in the same way as before. I still get several errors with the metadata file I attached to my original post to the list, all of which are definitely related to running the XSLT within Geonetwork. I have verified that the stylesheet works fine from the command line using xsltproc.
Not really being in a position to debug this, and knowing it's being worked on elsewhere as part of Geonetwork's harvesting functionality, I think my best course of action is to wait for it to be added to Geonetwork trunk.
Thanks again for your help - much appreciated.
David Herbert
British Antarctic Survey.
