In trying to add the UK Gemini 2.2 metadata schema to GeoNetwork 3.0.4/5 I
need to point to the GML 3.2.x schema - but I get the following error if I
set the namespace as xmlns:gml="http://www.opengis.net/gml/3.2"
2016-07-26 15:07:08,564 WARN [geonetwork.datamanager] - WARNING:
evaluating XPath
gmd:identificationInfo/gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:temporalElement/gmd:EX_TemporalExtent/gmd:extent/gml:TimePeriod
against metadata failed - XSD validation message: \ncvc-complex-type.2.4.a:
Invalid content was found starting with element 'gml:TimePeriod'. One of '{"
http://www.opengis.net/gml":AbstractTimePrimitive\}' is expected. (Element:
gml:TimePeriod with parent element: gmd:extent) will NOT be shown by the
editor
But it works fine if I use xmlns:gml="http://www.opengis.net/gml" - but
that would be invalid.
The issue seems to be related to the fact the there is a static XMLResolver
which gets modified by the following ISO19139 schema (which uses another
GML - possibly 2.3.1?) and seems to use the unversioned URI as a reference.
Has anyone else seen something similar before I start delving too deeply
into how the resolver works?
Ian
Ian Turton
For the record, we fixed that with Ian during GeoNetwork workshop at Foss4g
by taking care of gml32 element in
https://github.com/geonetwork/core-geonetwork/blob/develop/schemas/iso19139/src/main/plugin/iso19139/layout/layout-custom-fields.xsl#L159
Cheers.
Francois
2016-07-26 18:59 GMT+02:00 Ian Turton <ijturton@anonymised.com>:
evaluating XPath
TimePeriod
editor
Ian
Ian Turton
What NetFlow Analyzer can do for you? Monitors network bandwidth and
traffic
patterns at an interface-level. Reveals which users, apps, and protocols
are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning
reports.http://sdm.link/zohodev2dev
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
