[GeoNetwork-users] First install to Geonetwork Website
Hello people,
I have run the exe on my windows machine and the installation works and I
can see the URL fine
using
http://localhost:8080/geonetwork/srv/en/links
but when I try to give other computers access to this website obviously
localhost will not work.
I have tried the IP address of the computer and the name of the computer
but when other people try this the get IE message
IE cannot display the webpage.
What do I need to do to allow people access to this website outside of the
computer it was installed on?
Thanks.
Toby
This message is intended for the addressee named and may contain confidential information.
If you are not the intended recipient, please delete it and notify the sender.
Views expressed in this message are those of the individual sender, and are not necessarily the views of their organisation.
Hi Toby
Localhost is contained within your server - you cannot access localhost
from an external node on your network
If you have a standard installation you will be using Jetty as a web
server. You can modify the Jetty Settings inside GAST gui. Goto Options -
Config. Set the IP to 0.0.0.0.
You should then be able to connect to geonetwork using computers IP or name.
Luke B
On Tue, Nov 6, 2012 at 1:02 PM, <toby.terupe@anonymised.com> wrote:
Hello people,
using
Thanks.
Toby
sender.
LogMeIn Central: Instant, anywhere, Remote PC access and management.
Stay in control, update software, and manage PCs from one command center
Diagnose problems and improve visibility into emerging IT issues
Automate, monitor and manage. Do more in less time with Central
http://p.sf.net/sfu/logmein12331_d2d
GeoNetwork-users mailing list
*Luke Bassett*
* <lukembassett@anonymised.com>*Melbourne Australia
