Hi
You have probably noticed that the map on the metadata details page is
broken.
The WMS service used to display the map area in the metadata detail page
has change recently from *http* to *https*, causing the malfunction, you
can find more details in
https://github.com/geonetwork/core-geonetwork/issues/2951
We have applied a fix and will release a patch version to fix this, but in
the meantime you can update the following file to fix it:
TOMCAT_DIR/webapps/geonetwork/WEB-INF/config-spring-geonetwork.xml
See the change in
https://github.com/geonetwork/core-geonetwork/pull/5154/commits/637cbdafb44d412b977b7acb74fda09519c31fdc
It will require restarting the application.
Jose García
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/>Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>Please consider the environment before printing
this email.*
