[GeoNetwork-users] Fixing error in database?
Hi there,
Would be grateful for suggestions on how to resolve the following database
error.
GeoNetwork starts, but on attempting to save records, an error is received.
Thanks
$ java -jar /home/user/geonetwork/web/geonetwork/WEB-INF/lib/mckoi-1.0.2.jar
Mckoi SQL Database ( 1.0.2 )
Copyright (C) 2000, 2001, 2002, 2003 Diehl and Associates, Inc. All rights
reserved.
Use: -h for help.
  Mckoi SQL Database comes with ABSOLUTELY NO WARRANTY.
  This is free software, and you are welcome to redistribute it
  under certain conditions. See LICENSE.txt for details of the
  GPL License.
com.mckoi.database.V2MasterTableDataSource ( lvl: 40 )
  Inconsistant: Row is indexed but marked as removed or uncommitted.
  Row: 510 Type: 3 Table: APP.Metadata
TCP JDBC Server (multi_threaded) on port: 9157.
Boot time: 393ms.
After start up, these errors are in log:
2011-06-21 15:19:16,831 INFO [jeeves.engine] - Memory used is : 223507 Kb
2011-06-21 15:19:16,831 INFO [jeeves.engine] - Total memory is : 466048 Kb
2011-06-21 15:19:16,832 INFO [jeeves.engine] - Startup time is : 26 (secs)
2011-06-21 15:19:16,832 INFO [jeeves.engine] - === System working
2011-06-21 15:19:25,522 DEBUG [jeeves.engine] - TransformerFactoryFactory:
de.fzi.dbs.xml.transform.CachingTransformerFactory
2011-06-21 15:19:25,537 DEBUG [jeeves.engine] - TransformerFactoryFactory:
produces transformer implementation net.sf.saxon.IdentityTransformer
2011-06-21 15:19:26,470 DEBUG [jeeves.engine] - TransformerFactoryFactory:
2011-06-21 15:19:28,727 DEBUG [jeeves.engine] - TransformerFactoryFactory:
2011-06-21 15:19:28,728 DEBUG [jeeves.engine] - TransformerFactoryFactory:
2011-06-21 15:19:28,794 DEBUG [jeeves.engine] - TransformerFactoryFactory:
2011-06-21 15:19:28,795 DEBUG [jeeves.engine] - TransformerFactoryFactory:
GN error on attempting to save existing record from edit page:
Error: Could not save form/ status 500 text: Internal Server Error - Try
again late
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fixing-error-in-database-tp6499066p6499066.html
