[GeoNetwork-users-fr] erreur exception jdbc4 myslq
Bonjour,
Nous sommes en train de passer à la version de Géosource 2.7.3, avec tomcat et mysql.
Suite à la migration, j'ai le message d'erreur ci-dessous sur la page de démarrage de géosource.
Est-ce du à une table ou un champs incompatible avec la version 2.7.3 ?
merci à vous
Raised exception while starting appl handler. Skipped.
Exception com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Unknown column 'shortcode' in 'field list'
Message Unknown column 'shortcode' in 'field list'
Handler org.fao.geonet.Geonetwork
Stack com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Unknown column 'shortcode' in 'field list' at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39) at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27) at java.lang.reflect.Constructor.newInstance(Constructor.java:513) at com.mysql.jdbc.Util.handleNewInstance(Util.java:409) at com.mysql.jdbc.Util.getInstance(Util.java:384) at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:1054) at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3562) at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3494) at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1960) at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2114) at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2696) at com.mysql.jdbc.PreparedStatement.executeInternal(PreparedStatement.java:2105) at com.mysql.jdbc.PreparedStatement.executeQuery(PreparedStatement.java:2264) at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:96) at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:96) at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:96) at jeeves.resources.dbms.Dbms.selectFull(Dbms.java:213) at jeeves.resources.dbms.Dbms.select(Dbms.java:176) at org.fao.geonet.languages.IsoLanguagesMapper.init(IsoLanguagesMapper.java:81) at org.fao.geonet.Geonetwork.start(Geonetwork.java:350) at jeeves.server.JeevesEngine.initAppHandler(JeevesEngine.java:541) at jeeves.server.JeevesEngine.init(JeevesEngine.java:170) at jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:78) at javax.servlet.GenericServlet.init(GenericServlet.java:160) at org.apache.catalina.core.StandardWrapper.initServlet(StandardWrapper.java:1274) at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1186) at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:1081) at org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:5033) at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5320) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901) at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877) at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:633) at org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:657) at org.apache.catalina.startup.HostConfig$DeployDescriptor.run(HostConfig.java:1637) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:439) at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303) at java.util.concurrent.FutureTask.run(FutureTask.java:138) at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) at java.lang.Thread.run(Thread.java:662)
Fabien
Bonjour,
2013/2/5 Fabien Blanchet <FBlanchet@anonymised.com>
Bonjour,
tomcat et mysql.
A priori, la migration de la base de données est incomplète. Vérifiez que
le script SQL a été appliqué en totalité
https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/sandbox/GeoSource/trunk/geosource/src/main/added/web/src/main/webapp/WEB-INF/classes/setup/sql-geosource/migrate/273/migrate-default.sql
ALTER TABLE IsoLanguages ADD shortcode varchar(2);
Salutations.
Francois
merci à vous
at
at
at
at
at
at
at
at
at
at
Fabien
Free Next-Gen Firewall Hardware Offer
Buy your Sophos next-gen firewall before the end March 2013
and get the hardware for free! Learn more.
http://p.sf.net/sfu/sophos-d2d-feb
GeoNetwork-users-fr mailing list
GeoNetwork-users-fr@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geonetwork-users-fr
Bonjour,
Je tiens tout d'abord à vous remercier pour votre réponse rapide. Le problème n'est pas complétement résolu. En effet, je n'arrive pas à lancer gast pour la création de la base. En complément de votre courriel précédent, vous serait-il possible de m'envoyer un lien vers le script complet de création de la base avec toutes les tables. Par exemple, je n'ai pour le moment que 4 champs dans la table Languages, alors qu'il faudrait à priori insérer le code suivant :
INSERT INTO Languages VALUES ('ara','???', 'ara','n', 'n');
Merci à vous
Fabien Blanchet
fblanchet@anonymised.com
Téléphone : 05 46 87 72 57
Fabien Blanchet
________________________________________
De : Francois Prunayre [fx.prunayre@anonymised.com]
Date d'envoi : mercredi 6 février 2013 07:54
À : Fabien Blanchet
Cc : geonetwork-users-fr@lists.sourceforge.net
Objet : Re: [GeoNetwork-users-fr] erreur exception jdbc4 myslq
Bonjour,
2013/2/5 Fabien Blanchet <FBlanchet@anonymised.com<mailto:FBlanchet@anonymised.com>>
Bonjour,
A priori, la migration de la base de données est incomplète. Vérifiez que le script SQL a été appliqué en totalité
Salutations.
Francois
merci à vous
Fabien
GeoNetwork-users-fr@lists.sourceforge.net<mailto:GeoNetwork-users-fr@anonymised.comsourceforge.net>
Bonjour,
Grâce à vos explications, je viens de réinstaller la base et intégrer les données. l'application a l'air de fonctionner sauf les vignettes (disparition). Et lorsque je clique sur "thumbnail" en mode édition (ou autre d'ailleurs), écran noir et obligation de rafraichir.
Avez-vous déjà constaté ce genre de problème ?
Merci à vous
Cordialement,
Fabien Blanchet
De : Fabien Blanchet
Date d'envoi : mercredi 6 février 2013 08:46
À : Francois Prunayre
Objet : RE : [GeoNetwork-users-fr] erreur exception jdbc4 myslq
Bonjour,
Merci à vous
Fabien Blanchet
Fabien Blanchet
À : Fabien Blanchet
Bonjour,
Bonjour,
Salutations.
Francois
merci à vous
Fabien
Le 6 février 2013 17:36, Fabien Blanchet <FBlanchet@anonymised.com> a
écrit :
Bonjour,
(disparition).
Pour les vignettes, il est nécessaire de récupérer les fichiers de la
version précédente dans le répertoire des données de la nouvelle version
(probablement WEB-INF/data/data/ mais il est possible de vérifier le chemin
exact dans admin > information système).
"écran noir", c'est étrange. En cliquant n'importe où dans l'"écran noir",
il ne disparait pas ?
Salutations.
Francois
Merci à vous
Cordialement,
Fabien Blanchet
Bonjour,
Merci à vous
Fabien Blanchet
Fabien Blanchet
À : Fabien Blanchet
Bonjour,
Bonjour,
tomcat et mysql.
Salutations.
Francois
merci à vous
at
at
at
at
at
at
at
at
at
at
Fabien
GeoNetwork-users-fr@lists.sourceforge.net>
