Je veux simplement confirmé que l'installation "automatique" depuis la page de configuration ne fonctionne pas.
Il n'est pas possible de recharger un des thésaurus issu de GéoSource par ce biais, alors que manuellement il n'y a pas de problème.
Le log de Tomcat donne ceci :
2011-08-10 15:39:38,064 INFO [jeeves.request] - HTML Request (from 0:0:0:0:0:0:0:1) : /geosource/srv/fr/thesaurus.upload
2011-08-10 15:39:38,065 DEBUG [jeeves.request] - Method : POST
2011-08-10 15:39:38,065 DEBUG [jeeves.request] - Content type : multipart/form-data; boundary=---------------------------8723974127529
2011-08-10 15:39:38,065 DEBUG [jeeves.request] - Accept : text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
2011-08-10 15:39:38,065 DEBUG [jeeves.request] - Session id is 807E1E270F07168FF805325DEA4BB86A
2011-08-10 15:39:38,121 DEBUG [jeeves.request] - Uploading file gemet-theme.rdf type: application/rdf+xml size: 24471
2011-08-10 15:39:38,121 DEBUG [jeeves.request] - File is called gemet-theme.rdf after simplification
2011-08-10 15:39:38,154 DEBUG [jeeves.request] - Adding to parameters: <fname type="file" size="24471" content-type="application/rdf+xml">gemet-theme.rdf</fname>
2011-08-10 15:39:38,154 INFO [jeeves.service] - Dispatching : thesaurus.upload
2011-08-10 15:39:38,154 DEBUG [jeeves.service] - -> parameters are :
<params>
<dir>theme</dir>
<mode>file</mode>
<url />
</params>
2011-08-10 15:39:38,155 ERROR [jeeves.service] - Exception when executing service
2011-08-10 15:39:38,155 ERROR [jeeves.service] - (C) Exc : java.lang.NullPointerException
2011-08-10 15:39:38,155 DEBUG [jeeves.service] - Raised exception while executing service
<error id="error">
<message />
<class>NullPointerException</class>
<stack>
<at class="org.fao.geonet.services.thesaurus.Upload" file="Upload.java" line="141" method="upload" />
<at class="org.fao.geonet.services.thesaurus.Upload" file="Upload.java" line="84" method="exec" />
<at class="jeeves.server.dispatchers.ServiceInfo" file="ServiceInfo.java" line="230" method="execService" />
<at class="jeeves.server.dispatchers.ServiceInfo" file="ServiceInfo.java" line="139" method="execServices" />
<at class="jeeves.server.dispatchers.ServiceManager" file="ServiceManager.java" line="408" method="dispatch" />
<at class="jeeves.server.JeevesEngine" file="JeevesEngine.java" line="705" method="dispatch" />
<at class="jeeves.server.sources.http.JeevesServlet" file="JeevesServlet.java" line="196" method="execute" />
<at class="jeeves.server.sources.http.JeevesServlet" file="JeevesServlet.java" line="110" method="doPost" />
<at class="javax.servlet.http.HttpServlet" file="HttpServlet.java" line="641" method="service" />
<at class="javax.servlet.http.HttpServlet" file="HttpServlet.java" line="722" method="service" />
</stack>
<request>
<language>fr</language>
<service>thesaurus.upload</service>
</request>
</error>
2011-08-10 15:39:38,156 INFO [jeeves.service] - -> dispatching to error for : thesaurus.upload
2011-08-10 15:39:38,190 INFO [jeeves.service] - -> transforming with stylesheet : C:\geosource\web\geosource\/xsl/error.xsl
2011-08-10 15:39:38,214 INFO [jeeves.service] - -> end error transformation for : thesaurus.upload
2011-08-10 15:39:38,214 INFO [jeeves.service] - -> error ended for : thesaurus.upload
Question concernant THManager : je suis sur Windows7 sur ce poste et j'ai de nombreux problèmes lors de l'installation... Quelqu'un l'utilise-t-il sous 7 ?
Merci
Florian Deruette
SIG L-R / CG34
De : Florian Deruette <fderuette-sig@anonymised.com>
À : "geonetwork-users-fr@lists.sourceforge.net" <geonetwork-users-fr@anonymised.comsts.sourceforge.net>
Envoyé le : Mardi 9 Août 2011 13h06
Objet : Re : [GeoNetwork-users-fr] Geosource 2.7.0-0 : Import de thésaurus externe
Bonjour,
J'ai testé rapidement il y a un mois avec THmanager et j'ai aussi eu un problème à l'import (manuel), ce n'étais pas une priorité mais nous allons aussi en avoir besoin...
Il me semble que l'export et réimport d'un thésaurus de Géosource posait aussi des problèmes.
Je vais refaire qq tests aussi.
Florian Deruette
SIG L-R / CG34
De : BrinTinKam <camille_prevost@anonymised.com>
À : geonetwork-users-fr@lists.sourceforge.net
Envoyé le : Mardi 9 Août 2011 5h53
Objet : Re: [GeoNetwork-users-fr] Geosource 2.7.0-0 : Import de thésaurus externe
Bonjour,
Aucun changement lorsque je modifie le nom, j'ai tenté TablesCG4skos.rdf, et
TablesCG44.rdf à tout hasard mais rien.
J'avais déjà tenté l'installation à la main mais ça n'avait pas marché non
plus. j'ai aussi essayé avec d'autres thesaurus externes récupérés (et qui
marchent en temps normal), mais rien du tout.
Cordialement.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Geosource-2-7-0-0-Import-de-thesaurus-externe-tp6663416p6667529.html
Sent from the GeoNetwork users francophone mailing list archive at Nabble.com.
uberSVN's rich system and user administration capabilities and model
configuration take the hassle out of deploying and managing Subversion and
the tools developers use with it. Learn more about uberSVN and get a free
download at: http://p.sf.net/sfu/wandisco-dev2dev
GeoNetwork-users-fr mailing list
GeoNetwork-users-fr@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geonetwork-users-fr
