[GeoNetwork-users] FW: geonetwork metadata import problems
Hi All,
I have geonetwork up and running on our server with windows 2003 server and apache.
When I try to batch import metadata, I get various errors such as ” Directory not found”; “Root element not set” or “SAX2 driver class org.apache.xerces.parsers.SAXParser not found”
Do you know what the problem could be?
I am trying to batch import the metadata from my PC to the server.
Attached is an example of the metadata that was originally created using the ISO template in ArcCatalog.
Thanks
Craig
Craig von Hagen
FAO-SWALIM/GLCN/Africover Projects
Tel: +254 20 374 3454
Fax: +254 20 374 3498
Cell: +254 733 921964
www.faoswalim.org; www.africover.org;
www.glcn.org; www.glcn-lccs.org
(attachments)
sm-100k-ref-clip.xml (17.1 KB)
Hi Craig,
Can you try the process from server to server (same machine) and see if the same problem occurs?
Ciao,
Jeroen
On May 23, 2006, at 9:35 AM, Craig von Hagen wrote:
Hi All,
Thanks
Craig
Craig von Hagen
<sm-100k-ref-clip.xml>
Yes it does. We tried straight on the server and it gives the same errors but “Root element not set” seems to occur more often if we try straight on the server…
Craig
From: Jeroen Ticheler [mailto:Jeroen.Ticheler@anonymised.com]
Sent: 23 May 2006 13:41
To: Craig von Hagen
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] FW: geonetwork metadata import problems
Hi Craig,
Ciao,
Jeroen
Hi All,
Thanks
Craig
Craig von Hagen
