[GeoNetwork-users] FW: GeoServer question
Dear GeoNetwork Developers,
Could you please assist Erik with the issues described below?
Many thanks in advance for your assistance J
Patrizia
-------- Messaggio Inoltrato --------
Oggetto:
GeoServer question
Data:
Wed, 6 May 2015 10:48:15 +0100
Mittente:
Erik Voges erik.voges@anonymised.com
A:
patrizia.monteduro@anonymised.com
CC:
‘Jeroen Ticheler’ jeroen.ticheler@anonymised.com
Dear Patrizia
I need to bother you with a quick question, if you could help me, please!
I installed Geonetwork 3.0 on a server, and I am trying to use the Geoserver interface, but I keep getting this strange exception when I try to add a new layer:
“org.apache.wicket.WicketRuntimeException: Exception in rendering component: [MarkupContainer [Component id = storesDropDown]]”
I have looked on the Geoserver web site and it seems like it is an issue that has been resolved … so I want to try to download the latest stable version of GeoServer, and install that with this new version of GeoNetwork. I can download a .war file with the latest Geoserver version … but I don’t know where to install it.
Currently, if I go to /usr/share/geonetwork/web/geoserver/WEB-INF/classes , there is only a small xml file called “rebel” and no other class files.
Do you know where I can leave the war file or class files for geoserver to upgrade it to the new version? Or is that not a feasible approach?
Do you perhaps have any other suggestion for how I can solve my problem?
My server is here: http://afrihost.sasscal.org:8080/geoserver/web
Erik
Erik Voges
Systems Engineer – OADC/KE
Description: cid:3451562359_1492530
DISCLAIMER & COPYRIGHT
This email and any accompanying attachments may contain confidential, proprietary information and attached artwork which is subject to international copyright laws. This information is private and protected by law and, accordingly if you are not the intended recipient, you are requested to delete this entire communication immediately and are notified that any disclosure, copying or distribution of or taking any action based on this information is prohibited.
Oggetto:
One more question …
Data:
Wed, 6 May 2015 14:52:32 +0100
Mittente:
A:
Dear Patrizia
I have one more quick question for you, but if you don’t recognize the answer immediately, then don’t bother with it.
With my previous version of Geonetwork (2.10 I think) I have this strange situation that if I start it up, it creates this temp database file which grows until it has consumed the entire available disk space.
835245116208 May 6 14:48 geonetwork.4b8a6528931757da.0.temp.db
Any idea why this is happening?
Thanks
Erik
(attachments)
Hi Patrizia, hi Erik,
If you want to use the latest geoserver version, you have several possibilities, depending on your geonetwork installation :
1) if you have installed geonetwork using the jar file. I think it is what you did.
Then, you are using jetty as the java servlet container. The root of the container is then /usr/share/geonetwork/web. This folder contains 2 folders, 'geonetwork' and 'geoserver'.
You could install geoserver on a temp folder, using the windows installer procided by geoserver : http://sourceforge.net/projects/geoserver/files/GeoServer/2.7.0/geoserver-2.7.0.exe
Then you copy replace /usr/share/geonetwork/web/geoserver by the content of the instance you just installed (C:\Program Files\GeoServer 2.7.0\webapps). This should do the trick.
If you are using linux, use the Paltform Independent Binary download. Unzip it and take the geoserver-2.7.0/webapps/geoserver folder)
2) Or you can use tomcat, for example, and use the war files. Then you will install each app separately : geonetwork using the geonetwork.war file (does not contain any geoserver instance) and geoserver using the geoserver.war file.
In a production environment, I believe this is the recommended solution.
Jean
Patrizia
*Oggetto: ***
GeoServer question
*Data: ***
*Mittente: ***
Erik Voges <erik.voges@anonymised.com> <mailto:erik.voges@anonymised.com>
*A: ***
patrizia.monteduro@anonymised.com <mailto:patrizia.monteduro@anonymised.com>
*CC: ***
'Jeroen Ticheler' <jeroen.ticheler@anonymised.com> <mailto:jeroen.ticheler@anonymised.com>
Dear Patrizia
I installed Geonetwork 3.0 on a server, and I am trying to use the Geo*server* interface, but I keep getting this strange exception when I try to add a new layer:
/“org.apache.wicket.WicketRuntimeException: Exception in rendering component: [MarkupContainer [Component id = storesDropDown]]”/
Erik
*Erik Voges
*Systems Engineer – OADC/KE
*Oggetto: ***
One more question ..
*Data: ***
*Mittente: ***
*A: ***
Dear Patrizia
Thanks
Erik
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
GeoNetwork-users mailing list
*Jean Pommier -- pi-Geosolutions*
Ingénieur, consultant indépendant
Tél. : (+33) 6 09 23 21 36
E-mail : jp@anonymised.com
Web : www.pi-geosolutions.fr
Many thanks Jean!
I followed you advice and installed separately on tomcat – your recommended step (2). Now my errors are resolved.
Best regards
Erik
From: Jean Pommier [mailto:jean.pommier@anonymised.com]
Sent: 09 May 2015 04:46 PM
To: Monteduro, Patrizia (NRL)
Cc: geonetwork-users@lists.sourceforge.net; erik.voges@anonymised.com
Subject: Re: [GeoNetwork-users] FW: GeoServer question
Jean
/* Font Definitions */
@font-face
{font-family:Wingdings;
panose-1:5 0 0 0 0 0 0 0 0 0;}
@font-face
{font-family:SimSun;
panose-1:2 1 6 0 3 1 1 1 1 1;}
@font-face
@font-face
{font-family:Calibri;
panose-1:2 15 5 2 2 2 4 3 2 4;}
@font-face
{font-family:"\@SimSun";
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0cm;
margin-bottom:.0001pt;
font-size:11.0pt;
font-family:"Calibri","sans-serif";
color:black;
mso-fareast-language:EN-US;}
a:link, span.MsoHyperlink
{mso-style-priority:99;
color:#0563C1;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
color:#954F72;
span.EmailStyle17
{mso-style-type:personal;
color:windowtext;}
span . EmailStyle18
color:#1F497D;}
span.EmailStyle19
{mso-style-type:personal-reply;
color:#1F497D;}
.MsoChpDefault
{mso-style-type:export-only;
font-size:10.0pt;}
@page WordSection1
{size:612.0pt 792.0pt;
margin:72.0pt 72.0pt 72.0pt 72.0pt;}
div.WordSection1
{page:WordSection1;}
Many thanks in advance for your assistance :slight_smile:
Patrizia
Oggetto:
GeoServer question
Data:
Mittente:
Erik Voges <mailto:erik.voges@anonymised.com> <erik.voges@anonymised.com>
A:
CC:
'Jeroen Ticheler' <mailto:jeroen.ticheler@anonymised.com> <jeroen.ticheler@anonymised.com44...>
Dear Patrizia
Erik
Erik Voges
Oggetto:
Data:
Mittente:
A:
Dear Patrizia
Thanks
Erik
GeoNetwork-users@lists.sourceforge.net <mailto:GeoNetwork-users@anonymised.comeforge.net>
E-mail : jp@anonymised.com <mailto:jp@anonymised.com>
Web : www.pi-geosolutions.fr <http://www.pi-geosolutions.fr>
(attachments)
Glad it helps !
Jean
Le 11/05/2015 16:41, Erik Voges a écrit :
Many thanks Jean!
Best regards
Erik
*From:*Jean Pommier [mailto:jean.pommier@anonymised.com]
*Sent:* 09 May 2015 04:46 PM
*To:* Monteduro, Patrizia (NRL)
*Cc:* geonetwork-users@lists.sourceforge.net; erik.voges@anonymised.com
*Subject:* Re: [GeoNetwork-users] FW: GeoServer question
Jean
    @font-face
    @font-face
    @font-face
    @font-face
    @font-face
    {margin:0cm;
    font-size:11.0pt;
    color:black;
    color:#0563C1;
    color:#954F72;
    span.EmailStyle17
    color:windowtext;}
    span . EmailStyle18
    color:#1F497D;}
    span.EmailStyle19
    color:#1F497D;}
    .MsoChpDefault
    font-size:10.0pt;}
    @page WordSection1
    div.WordSection1
    Patrizia
    *Oggetto: *
    GeoServer question
    *Data: *
    *Mittente: *
    *A: *
    *CC: *
    Dear Patrizia
    please!
    feasible approach?
    problem?
    Erik
    *Erik Voges
    *Oggetto: *
    *Data: *
    *Mittente: *
    *A: *
    Dear Patrizia
    Thanks
    Erik
    GeoNetwork-users@lists.sourceforge.net <mailto:GeoNetwork-users@anonymised.coms.sourceforge.net>
    GeoNetwork OpenSource is maintained athttp://sourceforge.net/projects/geonetwork
