Thanks for the tips Jose and Christian. I added the logo as Jose suggested and that solved all my harvesting problems! Christian, I also downloaded the version from the ftp site you recommended, I loved the version with the modifications but for some reason that version was also slowing down my system considerably so I had to remove it.
Claire
Sent: July 28, 2014 04:08
To: Christian Rüh
Cc: Claire Reis; geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] FW: unable to harvest data
Hi
I think this is related to the logos, seem there's a issue with latest version of 2.10 and the logos folder that is not taken properly. When saving the harvester as there're no logos, fail with this nasty error.
A solution is to go to the Logo Management form in the Administration panel and upload a sample logo image. After that in the harvester, select the uploaded logo and then should be possible to save it.
Jose García
On Mon, Jul 28, 2014 at 11:00 AM, Christian Rüh <christian.rueh@...927...<mailto:christian.rueh@…927…>> wrote:
Hi Claire,
I have the same problem and asked here like a month ago with no reply
Although, when I think of it, it had one reply, my own
"totally unrelated to my issue I stumbled across a modified version of
GN
(ftp://ftp.ifremer.fr/ifremer/sismer/donnees/SeaDataNet_Software/CSW/)
and deployed that war using Tomcat. Using that version the Local File
System Harvesting worked just fine."
I don't know if you want to give it a try but it worked for me. However,
I'm still really curious how this problem can be solved using the
"regular" version of GN.
Christian
Am 22.07.2014 18:28, schrieb Claire Reis:
Sent: July 22, 2014 11:11
To: 'geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@lists.sourceforge.net>'
Subject: unable to harvest data
I recently installed Geonetwork on a windows 7 server with the default options and database. When I try to harvest metadata of any type (eg. OGS Services, localfilesystem, ArcSDE server) I get the same generic message for all:
Unable to add a new entry
Error: error
Message:
Class: NullPointerException.
Any suggestions? I would really like to be able to use this software!
Claire Herbert
Coordinator
Lake Winnipeg Basin Information Network
Want fast and easy access to all the code in your enterprise? Index and
search up to 200,000 lines of code with a free copy of Black Duck
Code Sight - the same software that powers the world's largest code
search on Ohloh, the Black Duck Open Hub! Try it now.
http://p.sf.net/sfu/bds
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@lists.sourceforge.net>
Infragistics Professional
Build stunning WinForms apps today!
Reboot your WinForms applications with our WinForms controls.
Build a bridge from your legacy apps to the future.
http://pubads.g.doubleclick.net/gampad/clk?id=153845071&iu=/4140/ostg.clktrk
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net/> for details.
_________________________
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/>
