Hi Robert,
To chip in here with my 02c worth...
The UI was built using the Silverstripe CMS/web framework by Silverstripe themselves & funded by two NZ Govt agencies, LINZ & MORST for http://www.geodata.govt.nz (If you want to know more about them - Google is your friend
While I was not involved in the original development, I very happily reused the tool (Silverstripe is also FOSS) in the http://www.os2020.org.nz website.
FYI, our use of Geonetwork & the Silverstripe interface is described in a teleconferece presentation to the Australasian Geonetwork User Group, now available at:
http://www.osdm.gov.au/Metadata/GeoNetwork/Resources/11_BWood_GN_NIWA_20111114.pdf/?id=1178
It provides a much friendlier user interface, hiding much of the complexity of ISO 19115 compliant metadata from the user. I use it as a read only tool, as we manage the content in house.
It has since been redeployed in a marine biosecurity portal, and will shortly go live again for web access to data & reports from a major offshore survey around New Zealand, the advantages of Open Source technology being obvious.
Brent Wood
--- On Tue, 2/14/12, Robert Buckley <robertdbuckley@anonymised.com> wrote:
From: Robert Buckley <robertdbuckley@anonymised.com>
Subject: Re: [GeoNetwork-users] Gallery of GeoNetwork Nodes
To: "geonetwork-users@lists.sourceforge.net" <geonetwork-users@anonymised.comforge.net>
Date: Tuesday, February 14, 2012, 6:59 PM
Fantastic looking application with slick interface....do you have any links decscribing how your organization created this?
It would be invaluable for the list.
yours,
Robert
Von: jforne <jforne@anonymised.com>
An: geonetwork-users@lists.sourceforge.net
Gesendet: 3:17 Dienstag, 14.Februar 2012
Betreff: [GeoNetwork-users] Gallery of GeoNetwork Nodes
Hi there
I am keen to include www.geodata.govt.nz on the list of known GeoNetwork
opensource based catalogues.
The http://geonetwork-opensource.org/gallery/gallery.html#geonetwork-nodes
Geonetwork opensource website suggests that I "Send us an email if you want
your node to be listed here." Unfortunately, I don't know what email I
should us. Can someone please help me?
Thanks in anticipation,
John
View this message in context: http://osgeo-org.1560.n6.nabble.com/Gallery-of-GeoNetwork-Nodes-tp4467294p4467294.html
Keep Your Developer Skills Current with LearnDevNow!
The most comprehensive online learning library for Microsoft developers
is just $99.99! Visual Studio, SharePoint, SQL - plus HTML5, CSS3, MVC3,
Metro Style Apps, more. Free future releases when you subscribe now!
http://p.sf.net/sfu/learndevnow-d2d
GeoNetwork-users mailing list
