Hey Folks,
The compile instructions worked out ncely, it at least gave me gast.jar
I figured since I was running headless and gast.sh was trying for X11
and I could not pass the setupdb option I defaulted back to my original
list I was following and called GAST directly
The following is the command I initiated and the output it generated.
It still wants to start X11 on the headless machine but seems to not
setup the db stuff due to an invalid port number...
samper@anonymised.com:~/domains/samper.crazykids.ca/public_html/geonetwork/gast$
java -jar gast.jar -setupdb
Loading
/home/samper/domains/samper.crazykids.ca/public_html/geonetwork/bin/jetty.xml
2009-07-07 13:18:21.703::INFO: Logging to STDERR via
org.mortbay.log.StdErrLog
Jetty on Host: localhost
Jetty on Port: 8090
java.sql.SQLException: Illegal connection port value '3306:geonetwork'
So I checked to see what port mysql expects
ps aux | grep mysql
root 20022 0.0 0.2 1772 528 pts/2 S 13:13 0:00 /bin/sh
/usr/bin/mysqld_safe
mysql 20061 0.3 9.5 127908 18164 pts/2 Sl 13:13 0:02
/usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql
--pid-file=/var/run/mysqld/mysqld.pid --skip-external-locking
--port=3306 --socket=/var/run/mysqld/mysqld.sock
root 20062 0.0 0.3 2920 692 pts/2 S 13:13 0:00 logger
-p daemon.err -t mysqld_safe -i -t mysqld
for some reason it looks like mysql is running in safe mode on one line,
but also running in normal mode bellow it and the port seems to match.
ideas?
