hi list
2010/5/7 heikki <tropicano@anonymised.com>:
hi,
could you explain in more exact detail what you tried to do?
I am parsing file system (folders, file names, size, last modify date,
owner, group, privileges, etc etc) and writing coherent records in gn
db , modifying xml in column data and other records using SQL INSERT,
UPDATE and DELETE
when a new resource needs to be added, I create a new uuid and I
commit new information using SQL
If you update some part of the metadata in GeoNetwork's DB, you must
afterward re-index the Lucene index.
so, probably here's my problem...
but I have no idea how to re-index Lucene using bash...
restarting some service could be useful?
Also, the uuid is stored in the DB in
the table "metadata", column "uuid" for one, and it still is also there in
the complete metadata in table "metadata", column "data".
The UUIDs generated by GeoNetwork are normal UUIDs, but GeoNetwork also
works perfect with invalid UUIDs like {with-accolades-around-them} that
certain commercial software packages produce.
In fact there is no check at all on the format of UUIDs -- as long as they
are unique to each metadata, it should be fine.
So to resolve your problem please provide more information ...
kind regards
Heikki Doeleman
On Fri, May 7, 2010 at 12:01 AM, Enrico Gallo <enrico.gallo@anonymised.com>
wrote:
dear list,
I am developing a file system robot in bash in order to automatically
update geonetwork DB
I tried and generate uuid with uuidgen tool, but all new records in DB
are not shown by GN, till when a different UUID is set by GN itself
(v. 2.4)
I suppose UUID by uuidgen is not compliant with GN UUID; so, how can I
generate GN-compliant UUID using bash?
many thanks
Enrico Gallo
GeoNetwork-users mailing list
