[GeoNetwork-users] Generating directives for use in GeoNetwork 3.4.X [SEC=UNCLASSIFIED]
Hi Guys
Could someone possibly help me in generating directives for use in GeoNetwork 3.4.X editing interface
Are the three places I need to work:
1) .../WEB-INF/data/config/schema_plugins/iso19115-3/layout/config-editor.xml
      identify the root of snippets to be used
2) ... /WEB-INF/data/config/schema_plugins//iso19115-3/index-fields/index-subtemplate-fileds.xsl
    Or is that
  ... /WEB-INF/data/config/schema_plugins//iso19115-3/index-fields/index-subtemplate.xsl
      Create the snippets and identify their anchors
3) .../catalog/locales/en-editor.json
      Create the handles for the snippets
Eg:
1) IN .../WEB-INF/data/config/schema_plugins/iso19115-3/layout/config-editor.xml
   <for name="cit:party" addDirective="data-gn-directory-entry-selector">
      <directiveAttributes
              data-template-add-action="true"
              data-search-action="false"
              data-popup-action="true"
              data-template-type="contact"
              data-filter='{"_root": "cit:CI_*n*i*i*"}'
              data-variables="cit:role/cit:CI_RoleCode/@codeListValue~{role}"/>
  <!--I believe cit:CI_orgaNIsatIon and cit:CI_iNdIvIdual are unique -->
    </for>
2) IN index-subtemplate-fileds.xsl
  I note there seems to have been a change from:
    index-subtemplate-fileds.xsl to index-subtemplate.xsl;
    or vice versa
  <!-- Indexing Organisation -->
  <xsl:template mode="index"
                match="cit:CI_Organisation[count(ancestor::node()) = 1 and cit:name/gco:CharacterString]">
    <xsl:variable name="type" select="local-name(.)"/>
    <xsl:variable name="name"
                  select="string-join(cit:name/gco:CharacterString, ', ')"/>
    <Field name="_title"
           string="{if ($name != '')
                    then $name
                    else $type}"
           store="true" index="true"/>
    <xsl:call-template name="subtemplate-common-fields"/>
  </xsl:template>
3) IN .../catalog/locales/en-editor.json
  I can't quite work out what/when this is used
      "searchAnOrganisation": "Search for an organisation ...",
OR IS THAT
      "searchAorganisation": "Search for an organisation ...",
BLEYS Evert Mr
Data Manager
Australian Bureau of Agricultural and Resource Economics and Sciences
Department of Agriculture and Water Resources
GPO Box 858 Canberra City ACT Australia 2601
44 Mort St Braddon ACT 2612
Ph: +61 (0)2 6272 5627
Email: Evert.Bleys@anonymised.com
-----Original Message-----
Sent: Sunday, 22 July 2018 16:06
To: raean <Andrew.Rae@anonymised.com>; geonetwork-
users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Associated Resources not displaying
[Marketing Mail] [SEC=UNCLASSIFIED]
Hi Andrew,
This is Jose's answer to me regarding the same problem:
In 3.4.2 were done some changes in the way the side panel is configured,
previously was used a setting in the database, but now is configured in the
config-editor.xml, see https://github.com/geonetwork/core-
geonetwork/blob/3.4.x/schemas/iso19139/src/main/plugin/iso19139/layout/
config-editor.xml#L3076-L3085
You need to add that snippet in the views of your schema config-editor.xml
Thanks.
Peck
Sent: Friday, 20 July 2018 9:53 PM
To: geonetwork-users@lists.sourceforge.net
I am having the same issue with the loss of my Associating resources panel
recently as well, when moving from 3.02 to 3.42. I have yet to resolve it.
However I do have some clues in 3.02 the editor could be configured by
pasting a snippet of json code in a field under settings metadata
configuration > metadata editor configuration. e.g. This is the setup I used
for 3.0.2
For example
{"iso19110":{"defaultTab":"default","displayToolTip":false,"related":{"display
":true,"readonly":true,"categories":["dataset"]},"validation":{"display":true}}
,"iso19139":{"defaultTab":"default","displayToolTip":false,"related":{"display
":true,"categories":},"suggestion":{"display":true},"validation":{"display":tr
ue}},"dublin-
core":{"defaultTab":"default","related":{"display":true,"readonly":false,"cat
egories":["parent","onlinesrc"]}},"iso19115-
3":{"defaultTab":"default","displayToolTip":false,"related":{"display":true,"c
ategories":},"suggestion":{"display":true},"validation":{"display":true}},"iso
19139.anzlic":{"defaultTab":"default","displayToolTip":false,"related":{"displa
y":true,"categories":disp},"suggestion":{"display":true},"validation":{"displ
ay":true}}}
In the snippet of code you can see the various flags for switching things off
and on. Unfortunately I can no longer find it in 3.4.2 maybe it has moved else
where. I had a look under the editor application settings in user interface
settings to no luck. once this snippet is stored in the right place it may fix the
problem of configuring the editor for different schema.
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-users-
f3860293.html
Check out the vibrant tech community on one of the world's most engaging
tech sites, Slashdot.org! http://sdm.link/slashdot
GeoNetwork-users mailing list
Notice: This email and any attachments are confidential and may not be
used, published or redistributed without the prior written consent of the
Institute of Geological and Nuclear Sciences Limited (GNS Science). If
received in error please destroy and immediately notify GNS Science. Do not
copy or disclose the contents.
IMPORTANT - This email and any attachments have been issued by the Australian Government Department of Agriculture and Water Resources. The material transmitted is for the use of the intended recipient only and may contain confidential, legally privileged, copyright or personal information. You should not copy, use or disclose it without authorisation from the Department. It is your responsibility to check any attachments for viruses and defects before opening or forwarding them.
If you are not an intended recipient, please contact the sender of this email at once by return email and then delete both messages. Unintended recipients must not copy, use, disclose, rely on or publish this email or attachments. The Department of Agriculture and Water Resources is not liable for any loss or damage resulting from unauthorised use or dissemination of, or any reliance on, this email or attachments.
If you have received this e-mail as part of a valid mailing list and no longer want to receive a message such as this one, advise the sender by return e-mail accordingly. This notice should not be deleted or altered
Hi Bleys,
Le mar. 31 juil. 2018 à 08:16, Bleys, Evert <Evert.Bleys@anonymised.com>
a écrit :
Hi Guys
1)
2) ...
                Or is that
Eg:
1) IN
unique -->
    </for>
                or vice versa
                    then $name
                    else $type}"
  </xsl:template>
OR IS THAT
It is used here
https://github.com/geonetwork/core-geonetwork/blob/5d6be625c00afe9da3e522b1573b08e1bd9b8f23/web-ui/src/main/resources/catalog/components/edit/directoryentryselector/partials/directoryentrylistselector.html#L6
to set the placeholder depending on the type of directory.
Francois
BLEYS Evert Mr
Data Manager
> From: Peck-Choo Tan [mailto:P.Tan@anonymised.com]
> Hi Andrew,
the
config-editor.xml
> Thanks.
> Peck
> From: raean [mailto:Andrew.Rae@anonymised.com]
panel
it.
used
> for 3.0.2
> For example
> ue}},"dublin-
> ay":true}}}
things off
moved else
interface
may fix the
> f3860293.html
not
