Maybe it would be clearer if I asked about generating new "directories"
e
BLEYS Evert Mr
Data Manager
Australian Bureau of Agricultural and Resource Economics and Sciences
Department of Agriculture and Water Resources
GPO Box 858 Canberra City ACT Australia 2601
44 Mort St Braddon ACT 2612
Ph: +61 (0)2 6272 5627
Email: Evert.Bleys@anonymised.com
-----Original Message-----
From: Bleys, Evert [mailto:Evert.Bleys@anonymised.com]
Sent: Tuesday, 31 July 2018 15:57
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] Generating directives for use in GeoNetwork
3.4.X [SEC=UNCLASSIFIED]Hi Guys
Could someone possibly help me in generating directives for use in
GeoNetwork 3.4.X editing interfaceAre the three places I need to work:
1) .../WEB-INF/data/config/schema_plugins/iso19115-3/layout/config-
editor.xml
identify the root of snippets to be used
2) ... /WEB-INF/data/config/schema_plugins//iso19115-3/index-
fields/index-subtemplate-fileds.xsl
Or is that
fields/index-subtemplate.xsl
Create the snippets and identify their anchors
3) .../catalog/locales/en-editor.json
Create the handles for the snippetsEg:
1) IN .../WEB-INF/data/config/schema_plugins/iso19115-3/layout/config-
editor.xml
<for name="cit:party" addDirective="data-gn-directory-entry-selector">
<directiveAttributes
data-template-add-action="true"
data-search-action="false"
data-popup-action="true"
data-template-type="contact"
data-filter='{"_root": "cit:CI_*n*i*i*"}'
data-variables="cit:role/cit:CI_RoleCode/@codeListValue~{role}"/>
<!--I believe cit:CI_orgaNIsatIon and cit:CI_iNdIvIdual are unique -->
</for>2) IN index-subtemplate-fileds.xsl
I note there seems to have been a change from:
index-subtemplate-fileds.xsl to index-subtemplate.xsl;
or vice versa
<!-- Indexing Organisation -->
<xsl:template mode="index"
match="cit:CI_Organisation[count(ancestor::node()) = 1 and
cit:name/gco:CharacterString]">
<xsl:variable name="type" select="local-name(.)"/>
<xsl:variable name="name"
select="string-join(cit:name/gco:CharacterString, ', ')"/>
<Field name="_title"
string="{if ($name != '')
then $name
else $type}"
store="true" index="true"/>
<xsl:call-template name="subtemplate-common-fields"/>
</xsl:template>3) IN .../catalog/locales/en-editor.json
I can't quite work out what/when this is used
"searchAnOrganisation": "Search for an organisation ...", OR IS THAT
"searchAorganisation": "Search for an organisation ...",BLEYS Evert Mr
Data Manager
Email: Evert.Bleys@anonymised.com> -----Original Message-----
> From: Peck-Choo Tan [mailto:P.Tan@anonymised.com]
> Sent: Sunday, 22 July 2018 16:06
> To: raean <Andrew.Rae@anonymised.com>; geonetwork-
> Subject: Re: [GeoNetwork-users] Associated Resources not displaying
> [Marketing Mail] [SEC=UNCLASSIFIED]
> Hi Andrew,
> This is Jose's answer to me regarding the same problem:
> In 3.4.2 were done some changes in the way the side panel is
> configured, previously was used a setting in the database, but now is
> configured in the config-editor.xml, see
> https://github.com/geonetwork/core-
geonetwork/blob/3.4.x/schemas/iso19139/src/main/plugin/iso19139/layout
> config-editor.xml#L3076-L3085
> You need to add that snippet in the views of your schema
> config-editor.xml
> Thanks.
> Peck
> From: raean [mailto:Andrew.Rae@anonymised.com]
> Sent: Friday, 20 July 2018 9:53 PM
> I am having the same issue with the loss of my Associating resources
> panel recently as well, when moving from 3.02 to 3.42. I have yet to resolve
it.
> However I do have some clues in 3.02 the editor could be configured by
> pasting a snippet of json code in a field under settings metadata
> configuration > metadata editor configuration. e.g. This is the setup
> I used for 3.0.2
> For example
> {"iso19110":{"defaultTab":"default","displayToolTip":false,"related":{
> "display
> ":true,"readonly":true,"categories":["dataset"]},"validation":{"displa
> y":true}}
> ,"iso19139":{"defaultTab":"default","displayToolTip":false,"related":{
> "display
> ":true,"categories":},"suggestion":{"display":true},"validation":{"d
> isplay":tr
> ue}},"dublin-
> core":{"defaultTab":"default","related":{"display":true,"readonly":fal
> se,"cat
> egories":["parent","onlinesrc"]}},"iso19115-
> 3":{"defaultTab":"default","displayToolTip":false,"related":{"display"
> :true,"c
> ategories":},"suggestion":{"display":true},"validation":{"display":t
> rue}},"iso
> 19139.anzlic":{"defaultTab":"default","displayToolTip":false,"related"
> :{"displa
> y":true,"categories":disp},"suggestion":{"display":true},"validation
> ":{"displ
> ay":true}}}
> In the snippet of code you can see the various flags for switching
> things off and on. Unfortunately I can no longer find it in 3.4.2
> maybe it has moved else where. I had a look under the editor
> application settings in user interface settings to no luck. once this
> snippet is stored in the right place it may fix the problem of configuring the
editor for different schema.
> Sent from: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-users-
> f3860293.html
> -------- Check out the vibrant tech community on one of the world's
> most engaging tech sites, Slashdot.org! http://sdm.link/slashdot
> GeoNetwork-users mailing list
> GeoNetwork-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geonetwork-users
> GeoNetwork OpenSource is maintained at
> http://sourceforge.net/projects/geonetwork
> Notice: This email and any attachments are confidential and may not be
> used, published or redistributed without the prior written consent of
> the Institute of Geological and Nuclear Sciences Limited (GNS
> Science). If received in error please destroy and immediately notify
> GNS Science. Do not copy or disclose the contents.
> http://sourceforge.net/projects/geonetwork------
IMPORTANT - This email and any attachments have been issued by the
Australian Government Department of Agriculture and Water Resources. The
material transmitted is for the use of the intended recipient only and may
contain confidential, legally privileged, copyright or personal information. You
should not copy, use or disclose it without authorisation from the
Department. It is your responsibility to check any attachments for viruses and
defects before opening or forwarding them.If you are not an intended recipient, please contact the sender of this email
at once by return email and then delete both messages. Unintended
recipients must not copy, use, disclose, rely on or publish this email or
attachments. The Department of Agriculture and Water Resources is not
liable for any loss or damage resulting from unauthorised use or
dissemination of, or any reliance on, this email or attachments.If you have received this e-mail as part of a valid mailing list and no longer
want to receive a message such as this one, advise the sender by return e-
mail accordingly. This notice should not be deleted or altered
Check out the vibrant tech community on one of the world's most engaging
IMPORTANT - This email and any attachments have been issued by the Australian Government Department of Agriculture and Water Resources. The material transmitted is for the use of the intended recipient only and may contain confidential, legally privileged, copyright or personal information. You should not copy, use or disclose it without authorisation from the Department. It is your responsibility to check any attachments for viruses and defects before opening or forwarding them.
If you are not an intended recipient, please contact the sender of this email at once by return email and then delete both messages. Unintended recipients must not copy, use, disclose, rely on or publish this email or attachments. The Department of Agriculture and Water Resources is not liable for any loss or damage resulting from unauthorised use or dissemination of, or any reliance on, this email or attachments.
If you have received this e-mail as part of a valid mailing list and no longer want to receive a message such as this one, advise the sender by return e-mail accordingly. This notice should not be deleted or altered
