I am facing a problem while installing Geonetworks. Please help me. While
installing It gives me the following error:
TransformerConfigurationException
Could not compile stylesheet
http://www.nabble.com/file/p16944558/error.jpg
Further i say yes to continue which finishes the installation however on
starting the server and trying to go to open geonetwork , i get the
following error
Site Error
An error was encountered while publishing this resource.
Resource not found
Sorry, the requested resource does not exist.
Check the URL and try again.
Resource: geonetwork GET
Troubleshooting Suggestions
* The URL may be incorrect.
* The parameters passed to this resource may be incorrect.
* A resource that this resource relies on may be encountering an error.
For more detailed information about the error, please refer to the error
log.
If the error persists please contact the site maintainer. Thank you for your
patience.
Please let me know the problem..
I have the jre1.6.0 installed.
View this message in context: http://www.nabble.com/Geo-Network-Installation-error-tp16944558s18419p16944558.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
Please try to install in a directory that does not contain spaces. for example in c:\geonetwork
Ciao,
Jeroen
On Apr 28, 2008, at 7:59 PM, learngeo wrote:
following error
Site Error
Resource not found
log.
patience.
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference
Don't miss this year's exciting event. There's still time to save $100.
Use priority code J8TL2D2.
http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
I think you have another aplication runing, maybe an old instalation of
geonetwok?, try to complete the install and run stop-geonetwork , be sure
too tha tomcat is not runing, after that, unistall and install again
Best regards
learngeo wrote:
following error
Site Error
Resource not found
error.
log.
your patience.
View this message in context: http://www.nabble.com/Geo-Network-Installation-error-tp16944558p17080294.html
