[GeoNetwork-users] GeoentWork performance problem
We have a question about GeonetWork Performance. Currently, 440,000
datasets are stored in GN, but the search performance is quite slow. If we
search by nothing, it takes around 15 seconds to get the first 50 datasets.
If we search by a keyword such as “water”, it takes 8 seconds.
Most of them are from NASA ECHO who has made some modification to iso19115
format, so some attributes cannot be recognized by GN. We are suspecting
this is the reason for the low performance.
Best,
Kai Liu
Ph.D. student
Department of Geography and GeoInformation Science
George Mason University
Hi Kai,
The problem relates to extracting the permissions/ownership stuff from the database when processing the records returned from the search (before returning for display). I have a fix I'll commit shortly - see buildExtraMetadataInfo in DataManager slows search in html5ui for larger catalogues · Issue #846 · geonetwork/core-geonetwork · GitHub
Simon
________________________________________
Sent: Friday, 20 March 2015 7:09 AM
To: Geonetwork-Users@anonymised.com
Subject: [GeoNetwork-users] GeoentWork performance problem
Best,
Kai Liu
Ph.D. student
I think Jesse and François has improved the data bases access during the
search, few monthes ago in develop.
Simon you should check with them that you are not doing agin the same thing
:wink:
On Fri, Mar 20, 2015 at 5:29 AM, <Simon.Pigot@anonymised.com> wrote:
Hi Kai,
Simon
Best,
Kai Liu
Ph.D. student
Dive into the World of Parallel Programming The Go Parallel Website,
sponsored
by Intel and developed in partnership with Slashdot Media, is your hub for
all
things parallel software development, from weekly thought leadership blogs
to
news, videos, case studies, tutorials and more. Take a look and join the
conversation now. http://goparallel.sourceforge.net/
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Florent Gravin
Camptocamp - Chambéry
0479444492
2015-03-20 9:34 GMT+01:00 Florent Gravin <florent.gravin@anonymised.com>:
:wink:
We did on develop, not 2.10.x
Francois
> Hi Kai,
the
> https://github.com/geonetwork/core-geonetwork/issues/846
> Cheers,
> Simon
> From: Kai Liu [kliu.gis@anonymised.com]
> Hi,
we
datasets.
iso19115
> Best,
> Kai Liu
> Ph.D. student
> sponsored
for
> all
blogs
> to
> https://lists.sourceforge.net/lists/listinfo/geonetwork-users
> http://sourceforge.net/projects/geonetwork
Florent Gravin
0479444492
sponsored
all
to
Thanks Simon and all.
We are using the v2.10.4 release version. That is probably why. And we are
using PostgreSQL + PostGIS.
I am wondering if there is a way to just replay some classes in the
release version.
Thanks and best regards,
On Fri, Mar 20, 2015 at 4:37 AM, Francois Prunayre <fx.prunayre@anonymised.com>
thing
> :wink:
Francois
> Cheers
> > Hi Kai,
> the
> > Cheers,
> > Simon
> > Hi,
> we
> datasets.
> iso19115
suspecting
> > Best,
> > Kai Liu
> > Ph.D. student
> > sponsored
> for
> > all
> blogs
> > to
the
> > _______________________________________________
> Florent Gravin
> 0479444492
> sponsored
for
> all
blogs
> to
sponsored
all
to
Kai Liu
Ph.D. student
I tried to create the installer the source code following the instructions
on http://geonetwork
-opensource.org/manuals/trunk/eng/developer/development/index.html.
but problems came one by one when I use the command "mvn clean install".
First, it has the error:
[ERROR] Child module
/Users/kailiu/Downloads/core-geonetwork-develop/geoserver/pom.xml of
/Users/kailiu/Downloads/core-geonetwork-develop/pom.xml does not exist
Then I commented out the geoserver module, it comes:
[ERROR] Failed to execute goal on project csw-server: Could not resolve
dependencies for project
org.geonetwork-opensource:csw-server:jar:3.0.0-SNAPSHOT: Could not find
artifact org.geonetwork-opensource:core:jar:tests:3.0.0-SNAPSHOT in
core-maven-repo (
https://raw.githubusercontent.com/geonetwork/core-maven-repo/master) ->
[Help 1]
Do you have any suggestions to create the installer using the develop
version?
release version.
thing
> :wink:
Francois
> Cheers
> > Hi Kai,
> the
> > Cheers,
> > Simon
> > Hi,
If
> we
> datasets.
> iso19115
suspecting
> > Best,
> > Kai Liu
> > Ph.D. student
> > sponsored
> for
> > all
> blogs
> > to
the
> Florent Gravin
> 0479444492
> sponsored
for
> all
blogs
> to
sponsored
for all
blogs to
Kai Liu
Ph.D. student
Kai Liu
Ph.D. student
2015-03-26 3:07 GMT+01:00 Kai Liu <kliu.gis@anonymised.com>:
instructions on http://geonetwork
instead you should probably do
git submodule init
git submodule update
core-maven-repo (
[Help 1]
version?
It should work well AFAIK.
Francois
are using PostgreSQL + PostGIS.
release version.
the
thing
> :wink:
Francois
> Cheers
> > Hi Kai,
from
> the
> > Cheers,
> > Simon
> > Hi,
If
> we
> datasets.
> iso19115
suspecting
> > Best,
> > Kai Liu
> > Ph.D. student
> > sponsored
hub
> for
> > all
> blogs
> > to
the
> Florent Gravin
> 0479444492
> sponsored
for
> all
blogs
> to
the
sponsored
for all
blogs to
Kai Liu
Ph.D. student
Kai Liu
Ph.D. student
