Hello,
could you explain me, what does the "geonet:choose" syntax mean ?
It's used in conditions like:
<xsl:if test="geonet:choose or $subtemplates">
<xsl:for-each select="geonet:choose">
We have found only one file with such syntax, in all GN: metadata.xsl.
Similiar example (also with unrecognized meaning):
<xsl:when
test="*[namespace-uri(.)!=$geonetUri]|@*|geonet:child|geonet:element/geonet:attribute">.
What is "geonet" namespace for?
Thanks for all your replies.
Cheers, Lukasz.
View this message in context: http://www.nabble.com/geonet-namespace---geonet%3Achoose-tf4757058s18419.html#a13603540
Sent from the geonetwork-users mailing list archive at Nabble.com.
