[GeoNetwork-users] Geonetwork 2.1.0 installation without X
Hello!
I'm installing geonetwork 2.1.0 on debian etch, with postgresql
8.2.5database, to run with tomcat5 and apache2.
As installation example I used
http://geonetwork-opensource.org/documentation/how-to/installation-on-ubuntu(it
is for
2.0.3)
In installation process missed steps where I can define database parameters
etc.
1.How can I define this parameters?! Is it possible to define it after
geonetwork installation?!
2.Is it possible to install geonetwork without graphical installer, in shell
(for example on server without X)?!
As root in shell i get:
Xlib: connection to ":0.0" refused by server
Xlib: No protocol specified
Exception in thread "main" java.lang.InternalError: Can't connect to X11
window
server using ':0.0' as the value of the DISPLAY variable.
etc...
Thanks!
pb
Hello Peteris, regarding your first question, you have to use GAST to set up a new database.
Check the manual under directory docs\manuals for more info about GAST.
For the second question, I'm not sure, any ideas? You could do the installation on a machine and then move the GeoNetwork dir to another (checking db connection)...
HTH. Francois
-----Message d'origine-----
De : geonetwork-users-bounces@lists.sourceforge.net [mailto:geonetwork-users-bounces@lists.sourceforge.net] De la part de Peteris Bruns
Envoyé : dimanche 21 octobre 2007 12:29
À : geonetwork-users@lists.sourceforge.net
Objet : [GeoNetwork-users] Geonetwork 2.1.0 installation without X
Hello!
is for
2.0.3)
etc.
window
etc...
Thanks!
pb
GeoNetwork-users mailing list
GAST has a command line option to do the setup:
java -jar gast/gast.jar -setup
At the end of the process it shows a dialog asking if it has to install sample metadata.
I did not try this command in headless mode. Maybe the first phase (the real installation)
could work.
HTH. Francois
Hello!
is for
2.0.3)
etc.
window
etc...
Thanks!
Thanks Andrea and Francois about gstat at eve I'll try to test it.
Maybe is some documentation or someone have experience to install GeoNetwork
on headless mode?! On my desktop machine with debian is ok to install with
GUI but server is headless and I'm sceptic to move geonetwork dir as was
recommended :slight_smile: because server is running on other distribution.
Thanks!
pb
sample metadata.
real installation)
could work.
> HTH. Francois
Bruns
> Hello!
> is for
> 2.0.3)
parameters
> etc.
shell
> window
> etc...
> Thanks!
Hi Peteris,
I have done an installation without X but it would seem that using GAST is a necessity at this point. For a truly headless install, I think the easiest way is to grab the latest source code from the SVN and compile the necessary jar files. If you need instructions on how to do this, I can provide these separately. Otherwise, if you have a machine with a graphical user interface, you can just download the current installer version and run the installer. However, even though I got everything running from the SVN files, I was forced to used GAST to get geonetwork running.
If you are using Tomcat, you will need to copy over these over (at the very least) the geonetwork and intermap directories to your tomcat webapps directory.If you need the geoserver functionality (I already had an instance on my server, and did not want the one that is packaged with geonetwork), you will need to copy over the geoserver directory as well into your Tomcat webapps directory. You may need to provide geonetwork and intermap with elevated security privileges depending on your Tomcat install. This should be done in /etc/tomcat5.5/policy.d/ . If you need specifics let me know. I am not sure this step is entirely necessary, but I did it anyway for my test install.
I was not able to successfully install geonetwork without GAST, and I could not get GAST to run per Andrea's instructions on a headless machine. I grabbed a machine with a UI and connected to the database on the remote machine and ran the setup function of GAST< and everything worked fine. GAST populates the database with certain necessary information, which is critical for the function of geonetwork. What this information is still a bit of a mystery to me. This information is not part of the SQL scripts that come with geonetwork, and you will only get Null Pointer Exceptions if you create the database without running GAST. I would really like to have a truly headless installer, and it will be on my wish list during the Geonetwork conference in Rome in a few weeks. Perhaps a modified SQL script with this "base" information would be good for those of us that do not have the luxury of a GUI on our geonetwork boxes. :slight_smile:
Sorry for this rather sparse email, but I can provide you more detailed information if you need it. Good luck.
Best regards,
Jason
-----Original Message-----
From: geonetwork-users-bounces@lists.sourceforge.net [mailto:geonetwork-users-bounces@lists.sourceforge.net] On Behalf Of Peteris Bruns
Sent: 21 October 2007 12:29
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] Geonetwork 2.1.0 installation without X
Hello!
is for
2.0.3)
etc.
window
etc...
Thanks!
pb
An installation without X would be nice indeed.
Running 'java -jar gast/gast.jar -setup' still requires X. Moreover, it
fails miserably when config.xml is configured to use another DB (in my
case MySQL). It tries to use the McKoi credentials to authenticate with
MySQL DB.
One can create the tables using the sql script in gast/setup/sql/ but the
tables need to be subsequently filled with initial data, and that requires
GAST.
I suppose that the freshly set-up/filled database could be dumped
(mysqldump for MySQL) and then used to populate the initial data instead
of using GAST on subsequent headless install.
A problem with this would be the Settings table, which contains the siteID
which is unique to each install, I suppose. Does GAST generate that id?
Also, having configured GN 2.1 for MySQL, I am unable to populate the DB
with the sample data using GAST (without the -setup switch). It gives
"You need to authenticate" error as described by Christian earlier.
Does anyone have a solution for this?
I have installed GN 2.1 on Ubuntu 7.04 with Java 1.5 JDK, MySQL and
Tomcat5.
I made a script that does the install on a fresh Ubuntu 7.04. It installs
Java, MySQL and Tomcat 5 and configures them also.
If anyone wishes to try it, here it is:
http://atlas.mems.uwindsor.ca/public/geonetwork_21.html
Paul
"Pēteris Brūns" <peteris.bruns@anonymised.com>
Sent by: geonetwork-users-bounces@lists.sourceforge.net
2007-10-22 08:29 AM
To
cc
Subject
Re: [GeoNetwork-users] Geonetwork 2.1.0 installation without X
Thanks!
pb
sample metadata.
real installation)
could work.
GAST.
> HTH. Francois
Bruns
> ? : geonetwork-users@lists.sourceforge.net
> Hello!
> is for
> 2.0.3)
parameters
> etc.
shell
X11
> window
> etc...
> Thanks!
