[GeoNetwork-users] GeoNetwork 2.10 / 2.10.1: MD_Metadata / fileIdentifier either not unique or missing in xml-metadata
Dear all,
over here we are now doing some tests with GeoNetwork 2.10.1. We have
serious problems with editing metadata.
The problem is, that I do not find any possiblitiy to make GeoNetwork create
a uuid for the MD_Metadata / fileIdentifier in the xml of the metadata.
Either it is always the same uuid for MD_Metadata / fileIdentifier or it is
missing and looks like this in the xml-metadata:
<gmd:MD_Metadata xsi:schemaLocation="http://www.isotc211.org/2005/gmd
http://www.isotc211.org/2005/gmd/gmd.xsd http://www.isotc211.org/2005/srv
http://schemas.opengis.net/iso/19139/20060504/srv/srv.xsd&quot;&gt;
  <gmd:fileIdentifier>
    <gco:CharacterString/>
  </gmd:fileIdentifier>
For testing I used a templed we created some time ago with GeoNetwork 2.4.x
/ 2.6.x / and I used the template "iso19139... preferred" coming with
GeoNetwork 2.10.1. For editing the metadate I took the following steps:
1. I created a new group catalogue "testdatensaetze".
2. I created an editor, a reviewer and a user admin for "testdatensaetze".
3. The editor created the dataset metadata, but even after saving the GUI
shows for the MD_Metadata / fileIdentifier "Value will be set when record is
saved."
4. The reviewer set the prviledges, but it is all the same >> after
modifying the metadata the GUI shows for the fileIdentifier still "Value
will be set when record is saved."
After that I logged off / on with several users. The right-management works
perfectly fine.
*Here is the result for the GeoNetwork-Template I "iso19139... preferred":*
The uuid for the fileIdentifier won´t show up. It´s not even in the xml of
the metadata created from that template. In fact, this template has not a
MD_Metadaten / fileIdentifier. That might be okay. Templates do not need no
MD_Metadata / fileIdentifier. Metadata need MD_Metadata / fileIdentifier.
With the MD_Metadata / fileIdentifier you create the GetRecordById Request
for CSW. So I tried that one just the way I always did in GN 2.6.4:
Click on the "Permanent link for the metadata", so that the fileIdentifier
uuid shows up in the url-field of the browser. But: As soon as I click on
"show metadata" in the search-results, there is an error message:
"Die angefragte Aufgabe konnte nicht erledigt werden.
XPathException : Template UNKNOWNBrief has not been defined"
Okay, not so much of a problem for us we use a template of our own (I
thought. But the truth is, the problem might come from the missing
MD_Metadata / fileIdentifier.)
*Here is the result for the template of our own, originally coming from
2.4.x / 2.6.x:*
I created three dataset metadata with the template of our own. We always use
that template and it has 74088940-18c1-404e-a65c-650aa7b53461 as an
MD_Metadata / fileIdentifier after importing in GeoNetwork 2.10.1. This uuid
from our template off course has not been used over and over again by the
older GeoNetwork versions, because for each new metadata created from that
template, GeoNetwork creates a new uuid as MD_Identifier / fileIdentifier
for each metadata.
Unfortunately in GeoNetwork 2.10 and in GeoNetwork 2.10.1 GeoNetwork just
keeps the static uuid for each metadata. But, when you use the button
"permanent link to metadata" you can see the true uuid in the browser
because the url is displayed here. For the url-field of the browser all
metadata have an unique uuid. Problem: this uuid does not show up in the
xml-metadata. A GetRecordById Request cannot be answered (There is a
response, saying <csw:GetRecordByIdResponse/>; so it is all empty.)
This is a serious problem, I think. Please don´t refer to the workaround
taken the uuid from the browser and putting it into the xml-metadata via
xml-editing of the GUI. It might work, although I haven´t checked, but
people editing metadata hardly know what an url, a browser or an uuid is.
Any help highly appreciated. I am so sorry, if this was a true bug :frowning: Do we
have any chance in trying another configuration of anything?
Greetings,
Anja
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-2-10-2-10-1-MD-Metadata-fileIdentifier-either-not-unique-or-missing-in-xml-metadata-tp5072731.html
Hello,
Have you come to any resolution to this problem? I agree that this is a
serious problem. My experience is that the new UUIDs are created in the
database but this is not reflected in the metadata itself. This in my mind
and for the users I am trying to support, make the metadata pretty much
useless.It certainly breaks the ability to link a child to a parent.
I plan on looking into this further when I can find some time. I am not
convinced it is a problem across all schemas. Has anyone any more insight
into this problem? Or any suggestions as to where I should start looking.
This behaviour was present in 2.10.2 and 2.10.3. Not sure about earlier.
Byron
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-2-10-2-10-1-MD-Metadata-fileIdentifier-either-not-unique-or-missing-in-xml-metadata-tp5072731p5102013.html
A quick followup - It seems that to trigger the creation of a new
fileidentifier, the entire element must be removed, but this is not
happening in the metadata creation routines such as create or create child.
Deleteing the <gmd:fileidentifier> on creation would likely solve the issue.
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-2-10-2-10-1-MD-Metadata-fileIdentifier-either-not-unique-or-missing-in-xml-metadata-tp5072731p5102017.html
Hi
This issue:
looks like for some reason is not identifying the schema for the metadata,
maybe there's any issue in the template or something wrong in the
installation. I have done a similar test with 2.10.2 with the html5ui and
looks fine for me.
About the uuids, are created in the database and also added in the metadata
xml.
Jose García
On Wed, Feb 5, 2014 at 11:03 AM, ByronCinNZ <cochranes4@anonymised.com> wrote:
Hello,
Byron
Managing the Performance of Cloud-Based Applications
Take advantage of what the Cloud has to offer - Avoid Common Pitfalls.
Read the Whitepaper.
http://pubads.g.doubleclick.net/gampad/clk?id=121051231&iu=/4140/ostg.clktrk
GeoNetwork-users mailing list
* GeoCat Bridge for ArcGIS allows instant publishing of data and metadata
on GeoServer and GeoNetwork. Visit http://geocat.net
<http://geocat.net/&gt; for details. _________________________Jose
GarcíaGeoCat bvVeenderweg 13 6721 WD BennekomThe
Netherlandshttp://GeoCat.net/> *
