Hi Michael,
Normally I give the JVM running GeoNetwork 1GB RAM and that works very well. More RAM will allow you to have more parallel sessions without running into memory heap exceptions. This should work under normal loads. By default user sessions were valid for three hours, but I think this has already been reduced to some 30 minutes in GN2.4.
You can see what recommended options for the JVM are used by studying the geonetwork startup file. They are:
java -Xms48m -Xmx512m -Xss2M -XX:MaxPermSize=128m -DSTOP.PORT=8079 -Djava.awt.headless=true
You see that by default it only gets 512MB and a minimum configuration only has 256MB.
Hope this helps, ciao,
Jeroen
On Sep 14, 2009, at 10:01 AM, <Michael.Stegherr@anonymised.com> <Michael.Stegherr@anonymised.com > wrote:
What are the current minimum requirements regarding memory for GeoNetwork 2.4?
This page mentions "2MB" RAM, which should probably read "2GB", but is for version 2.0:
http://geonetwork-opensource.org/documentation/tutorial/administration/webinstallreq
Also what JAVA options are you recommending? I'm running GeoNetwork on a Linux box with Apache, Tomcat and Postgres.
I found some requests for recommended production environment characteristics and profiling on Nabble as well, but there has been no answer yet.
Can anyone give me a recommendation?
Michael Stegherr, Computer Scientist
CSIRO Exploration and Mining | Phone 08 6436 8572
AARC, 26 Dick Perry Av, Kensington WA 6151, Australia
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus on
what you do best, core application coding. Discover what's new with
Crystal Reports now. Best Open Source Mac Front-Ends 2024
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
