[GeoNetwork-users] GeoNetwork 2.4.2 installation
did you change/modify server.xml or any other .xml to point to intermap?
Changed further port settings?
I recommend to upgrade to a newer version of java and tomcat.
best regards
Sarah
View this message in context: http://n2.nabble.com/GeoNetwork-2-4-2-installation-tp4459267p4460064.html
why did you not copied the 3 webapps or set context? Did you tried it
otherwise?
I don´t use linux, only windows.
Do you get the same error? What said the log files?
best regards
Sarah
View this message in context: http://n2.nabble.com/GeoNetwork-2-4-2-installation-tp4459267p4467129.html
On Wed, 27 Jan 2010 05:29:39 -0800 (PST)
Sarah,
I'm not sure I understand what you are suggesting. I did a standard
install and tested it using Jetty and it worked fine. The following the
steps outlined in the tutorial I tried to get it to run with Apache and
Tomcat 5.5. Unfortunately now neither solution works and the logs are
blank since following the tutorial, so it would appear that nothing is
happening despite the fact that apache and tomcat are started and
appear to be functioning.
TSW
Sarah_S wrote:
otherwise?
best regards
Sarah
The Planet: dedicated and managed hosting, cloud storage, colocation
Stay online with enterprise data centers and the best network in the business
Choose flexible plans and management services without long-term contracts
Personal 24x7 support from experience hosting pros just a phone call away.
http://p.sf.net/sfu/theplanet-com
GeoNetwork-users mailing list
Hi Iren,
I would check connection url to mysql and mysql driver version.
I had no experience with mysql, only with postgres/postgis.
hope it helped a little.
best regards
Sarah
View this message in context: http://n2.nabble.com/GeoNetwork-2-4-2-installation-tp4459267p4472140.html
Hi Trevor,
if geonetwork has started you have to see that in your log file from Tomcat (or Apache). But I don´t use Apache only Tomcat.
Can you access http://localhost/geonetwork or something familiar? What are your errors?
I read your other question here: http://n2.nabble.com/Ubuntu-9-04-Tomcat-5-5-Geonetwork-2-4-2-404-geonetwork-srv-en-main-home-was-not-found-on-this-server-td4464249.html#a4464249 but I don´t have a solution for this, sorry.
best regards
Sarah
Von: Trevor Wiens <twiens@anonymised.com>
An: Sarah_S <Sarah_flip@anonymised.com>
CC: geonetwork-users@lists.sourceforge.net
Gesendet: Mittwoch, den 27. Januar 2010, 22:56:32 Uhr
Betreff: Re: [GeoNetwork-users] GeoNetwork 2.4.2 installation
Sarah,
TSW
Sarah_S wrote:
otherwise?
best regards
Sarah
__________________________________________________
Do You Yahoo!?
Sie sind Spam leid? Yahoo! Mail verfügt über einen herausragenden Schutz gegen Massenmails.
http://mail.yahoo.com
