I just installed GeoNetwork 2.4 and when I start the application, the map on
the left won't load.
I also get the following javascript errors in IE6:
- Expected identifier, string or number.
- 'Env' is undefined.
I'm using Tomcat 6 and MySQL 5 with Java 1.5
I also get the following error in the logs when starting Tomcat:
27 Aug 14:25:41 ERROR [context.ContextLoader] - Context initialization
failed
org.springframework.beans.factory.BeanCreationException: Error creating bean
with name 'applicationState' defined in URL
[file:/C:/geo/web/geoserver/WEB-INF/classes/applicationContext.xml]: Cannot
resolve reference to bean 'data' while setting constructor argument; nested
exception is org.springframework.beans.factory.BeanCreationException: Error
creating bean with name 'data' defined in URL
[jar:file:/C:/geo/web/geoserver/WEB-INF/lib/main-1.7.3.jar!/applicationContext.xml]:
Cannot resolve reference to bean 'geoServer2' while setting constructor
argument; nested exception is
with name 'geoServer2' defined in URL
Initialization of bean failed; nested exception is
java.lang.RuntimeException: java.io.FileNotFoundException: Could not find
services.xml under:C:\geo\web\geoserver\data
at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:275)
at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
at
org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:495)
at
org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:162)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at
org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at
org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
at
org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
at
org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
at
org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
at
org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
at
org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
at
org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
at
org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
at
org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3934)
at
org.apache.catalina.core.StandardContext.start(StandardContext.java:4429)
at
org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:791)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:771)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:526)
at
org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:630)
at
org.apache.catalina.startup.HostConfig.deployDescriptors(HostConfig.java:556)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:491)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1206)
at
org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:314)
at
org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1053)
at org.apache.catalina.core.StandardHost.start(StandardHost.java:722)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1045)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
at org.apache.catalina.core.StandardService.start(StandardService.java:516)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:710)
at org.apache.catalina.startup.Catalina.start(Catalina.java:583)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:288)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:413)
Caused by: org.springframework.beans.factory.BeanCreationException: Error
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
... 44 more
creating bean with name 'geoServer2' defined in URL
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:480)
at
at
at
at
at
at
at
at
... 59 more
Caused by: java.lang.RuntimeException: java.io.FileNotFoundException: Could
not find services.xml under:C:\geo\web\geoserver\data
at org.geoserver.config.GeoServerLoader.initialize(GeoServerLoader.java:95)
at
org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:81)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:350)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1330)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
... 68 more
Caused by: java.io.FileNotFoundException: Could not find services.xml
at
org.geoserver.config.util.LegacyImporterSupport.reader(LegacyImporterSupport.java:19)
at
org.geoserver.config.util.LegacyLoggingImporter.imprt(LegacyLoggingImporter.java:34)
at org.geoserver.config.GeoServerLoader.initialize(GeoServerLoader.java:92)
... 72 more
Am I missing something? Can anybody help me out.
Kevin
View this message in context: http://n2.nabble.com/GeoNetwork-2-4-map-is-not-loading-tp3529124p3529124.html
