Heikki,
I get the same thing, on restarting the system my geonetwork.log says:
2009-08-17 09:13:25,453 ERROR [geonetwork.search] - Rebuilding lucene index
I am running GN2.4 built from the installer using Java 1.5.0_14 and Win XP SP3.
Andrew Walsh
----- Original Message -----
To: Devel geonetwork-devel@lists.sourceforge.net ; Geonetwork Users
Sent: Saturday, August 15, 2009 6:06 AM
Subject: Re: [GeoNetwork-devel] Geonetwork 2.4 re-indexing every time onstart-up
OK -- testing again, I only have it using GN2.4, not GN2.2.
But it's consistently reproduceable for GN2.4. So I guess I can rule out that it could have anything to do with Java or XP, instead it must be something about the index reading / writing introduced with 2.4. I tried it with both a MySQL and a Postgres DB, and that doesn't make a difference (as it shouldn't).
Still I have no clue as to what that cause might be, though.. everything seems fine, the index does actually work perfectly fine for GN while the app is running, and before and after killing GN it's also just fine to view the index using Luke. When GN restarts, everything seems dandy, except that the IndexReader thinks that there are 0 docs in the index.
I'd be happy to hear from other people whether or not you have this issue in GN2.4.
Kind regards
Heikki Doeleman
On Fri, Aug 14, 2009 at 9:15 PM, heikki <tropicano@anonymised.com> wrote:
hello lists,
I'm having the following behaviour : everytime I re-start a GeoNetwork installation, it starts rebuilding the Lucene index, even though there already exists a Lucene index that's not empty and up-to-date.
I've this same issue using GeoNetwork 2.4 (both when built from SVN or when installed from the installer distro) and also using a modified version of Geonetwork 2.2.
I'm using Windows XP and my Java version is
java version "1.6.0_15"
Java(TM) SE Runtime Environment (build 1.6.0_15-b03)
Java HotSpot(TM) Client VM (build 14.1-b02, mixed mode, sharing)
The indexes that already exist when GN starts, are valid Luke indexes, which I can successfully view using Luke.
I've tried running a GN version with some extra debug logging, and SearchManager.java, when opening a Lucene IndexReader reports that the index exists, that the index reader is current, and (somehow) that the number of docs in the index is 0 (which is not true and causes the re-indexing).
I don't remember seeing this before. Did anyone else see this ? Could it be because of some Java or Windows XP update, that all of a sudden I'm getting this behaviour ?
Your comments welcome
kind regards
Heikki Doeleman
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
GeoNetwork-devel mailing list
