Hi all
The 2.6.1 release will be delayed until early next week. On monday an
important fix was applied to solve wildcard searches, but yesterday while
testing the installer we found a nasty related problem that causes the
searches to be broken.
We have a solution that needs testing in order to make a proper release.
Thanks and regards,
Jose García
Hi Jose.
Is there a new ETA please?
Ta,
Just.
From: jose garcia [mailto:josegar74@anonymised.com]
Sent: 04 November 2010 08:53
To: geonetwork-users@lists.sourceforge.net; geonetwork-devel@anonymised.comrge.net
Subject: [GeoNetwork-devel] GeoNetwork 2.6.1 release delayed
Hi all
The 2.6.1 release will be delayed until early next week. On monday an important fix was applied to solve wildcard searches, but yesterday while testing the installer we found a nasty related problem that causes the searches to be broken.
Thanks and regards,
Jose García
This email is only intended for the person to whom it is addressed and may contain confidential information. If you have received this email in error, please notify the sender and delete this email which must not be copied, distributed or disclosed to any other person.
Unless stated otherwise, the contents of this email are personal to the writer and do not represent the official view of Ordnance Survey. Nor can any contract be formed on Ordnance Survey's behalf via email. We reserve the right to monitor emails and attachments without prior notice.
Thank you for your cooperation.
Ordnance Survey
Romsey Road
Southampton SO16 4GU
Tel: 08456 050505
http://www.ordnancesurvey.co.uk
hello together,
if the release is delayed, maybe there is some time left to control if the
initial filling of the database can be done without having an xserver running
on the system. when running java -jar /geonetwork/gast/gast.jar -setupdb
(e.g. for postgres) up from version 2.5.0 - gast fails, cause it demands an
graphical environment. in normal situations of installing geonetwork it will
run on a server - maybe in a dmz. on such a server, there is no need to run
and update a whole graphical environment.
another point is that harvesting external resources over https (port 443) is
not possible. I think many implementations will use this protocoll, and
therfor this should be manageable in the harvesting configuration.
thanks and regards
armin
Am Mittwoch 10 November 2010, um 17:24:57 schrieb Justin Rowles (C):
Hi Jose.
Ta,
Just.
geonetwork-devel@lists.sourceforge.net Subject: [GeoNetwork-devel]
Hi all
Thanks and regards,
Jose García
Ordnance Survey
Romsey Road
Tel: 08456 050505
--- The Next 800 Companies to Lead America's Growth: New Video Whitepaper
David G. Thomson, author of the best-selling book "Blueprint to a
Billion" shares his insights and actions to help propel your
business during the next growth cycle. Listen Now!
http://p.sf.net/sfu/SAP-dev2dev
GeoNetwork-users mailing list
Im Auftrag
Armin Retterath
Kompetenz- und Geschäftsstelle Geodateninfrastruktur Rheinland-Pfalz
beim
Landesamt für Vermessung und Geobasisinformation Rheinland-Pfalz
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
armin.retterath@anonymised.com
http://www.geoportal.rlp.de
