[GeoNetwork-users] geonetwork 2.7 download + WMS publishing
Hello,
I need to be able to publish the datasets from geonetwork. In order to make
them directly accessible
(e.g. Google Earth, Interactive Maps) I need to provide a WMS link. Is it
possible to use geonetwork to publish data via WMS? If not.. are there any
other ways to use the files from the GN database and to have them put into a
WMS?
I read that v2.7 will be able to publish data via WMS (at least .shp). Is
there a download link for it?
regards, Chris
View this message in context: http://osgeo-org.1803224.n2.nabble.com/geonetwork-2-7-download-WMS-publishing-tp6897702p6897702.html
Hi Chris,
2011/10/16 test11 <nirirysatapuhyjy@anonymised.com>:
Hello,
WMS?
Check the doc [1].
It supports currently Zipped shapefile, Geotiff, Postgis Table and
external files (on local network or URL, check GeoServer REST API for
details and supported formats [2]).
HTH
Francois
[1] http://geonetwork-opensource.org/manuals/trunk/users/quickstartguide/new_metadata/index.html#publish-uploaded-data-as-wms-wfs-in-geoserver
[2] http://docs.geoserver.org/stable/en/user/restconfig/rest-config-api.html#data-stores
regards, Chris
All the data continuously generated in your IT infrastructure contains a
definitive record of customers, application performance, security
threats, fraudulent activity and more. Splunk takes this data and makes
sense of it. Business sense. IT sense. Common sense.
http://p.sf.net/sfu/splunk-d2d-oct
GeoNetwork-users mailing list
Thanks for the help, but unfortunately I don't know how to activate
geoserver in the config-gui.xml.
What do I need to change?
regards
View this message in context: http://osgeo-org.1803224.n2.nabble.com/geonetwork-2-7-download-WMS-publishing-tp6897702p6899509.html
2011/10/17 test11 <nirirysatapuhyjy@anonymised.com>:
At least to activate the geopublisher wizard in the metadata editor uncomment
  <!-- Display the geopublisher option for all updloaded files
   <editor-geopublisher/>-->
To configure GeoServer nodes to use see geoserver-nodes.xml.
HTH.
Francois
regards
This entry does not exist in my config-gui.xml
I have GN 2.6.4 installed.
You will find my xml attached.
regards
http://osgeo-org.1803224.n2.nabble.com/file/n6903485/config-gui.xml
config-gui.xml
View this message in context: http://osgeo-org.1803224.n2.nabble.com/geonetwork-2-7-download-WMS-publishing-tp6897702p6903485.html
