Hello,
We downloaded the geonetwork code from 2.8 branch and built the war file and we would like to enable the Widgets ExtJS based interface.Is this Interface available for all screens especially for the Metadata Editor screen.
After deploying we see the default interface.If widget interface is available can anyone please help how to enable that? Thanks.
Regards
Kumaran
Hello Kumaran, usually the widgets interface is available in the apps
folder (ie. http://localhost:8080/geonetwork/apps/). For the configuration
check the WEB-INF/config-gui.xml file [1]. To build the WAR with the
widgets use mvn with the -Pwidgets profile option [2].
Cheers.
Francois
[1]
http://trac.osgeo.org/geonetwork/wiki/proposals/WidgetsBasedGui#Configuration
[2]
http://osgeo-org.1560.n6.nabble.com/Building-widget-based-UI-td3875582.html
2013/1/3 Kumaran Narayanaswamy <kumaran.narayanaswamy@anonymised.com>
Hello,
screen.
Regards
Kumaran
Master Visual Studio, SharePoint, SQL, ASP.NET, C# 2012, HTML5, CSS,
MVC, Windows 8 Apps, JavaScript and much more. Keep your skills current
with LearnDevNow - 3,200 step-by-step video tutorials by Microsoft
MVPs and experts. ON SALE this month only -- learn more at:
http://p.sf.net/sfu/learnmore_122712
GeoNetwork-devel mailing list
