[GeoNetwork-users] GeoNetwork 3.0.1 language selection Combo Box
I tried lots of things and finally I can use my language as a default
language. But, I cannot change the language selection combobox which on the
upper right of the page.
Is there a way to add my own language and make it default for selections?
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-3-0-1-language-selection-Combo-Box-tp5226775.html
Hi
Languages seem hardcoded.
List of languages:
https://github.com/geonetwork/core-geonetwork/blob/develop/web-ui/src/main/resources/catalog/js/CatController.js#L47-L52
Default language:
https://github.com/geonetwork/core-geonetwork/blob/develop/web-ui/src/main/resources/catalog/js/CatController.js#L45
If you update that code, should get the new language, if you have defined
the translations for it, I guess.
Jose García
On Tue, Sep 29, 2015 at 12:37 PM, sercanerhan <sercanerhan@anonymised.com> wrote:
GeoNetwork-users mailing list
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>M: +31 (0)655 818332 <+31655818332>
<https://www.facebook.com/geocatbv&gt; <https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
Thank you Jose but, it didn't work for me.
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-3-0-1-language-selection-Combo-Box-tp5226775p5226808.html
Hi
Check if it's some web browser cache issue.
At least for the language switcher works for me with these changes:
* Updated $scope.langs and $scope.langLabels to remove unwanted languages
in CatController.js
For the default language, I was checking to update the default locale in
this file WEB-INF/spring-servlet.xml
<bean id="localeResolver"
  class="org.springframework.web.servlet.i18n.SessionLocaleResolver">
  <property name="defaultLocale" value="*eng*" />
  </bean>
I changed to fre for french, but no success. Need to check further how
works the default language stuff.
Jose García
On Tue, Sep 29, 2015 at 3:30 PM, sercanerhan <sercanerhan@anonymised.com> wrote:
Hi Jose,
I did try to clean browser's caches bur it didn't work for me. I want to add
turkish and my CatController.js includes these lines;
      $scope.langs = {'eng': 'en', 'dut': 'du', 'fre': 'fr',
        'ger': 'ge', 'tur': 'tr'};
      // Lang names to be displayed in language selector
      $scope.langLabels = {'eng': 'English', 'dut': 'Nederlands',
        'fre': 'Français', 'ger': 'Deutsch', 'tur':'Türkçe'};
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-3-0-1-language-selection-Combo-Box-tp5226775p5227181.html
Hi
I have added your code and for me the menu looks fine with Turkish. I'm
using the 3.0.x branch, not sure if that can make the difference.
I would try in debug mode:
http://SERVER/geonetwork/srv/eng/catalog.search?debug=true#/home
To check if the menu is displayed properly. If so I would check to cleanup
the wro cache files, that if not wrong should be in WEB-INF folder, and
retry in no debug mode.
Jose García
On Thu, Oct 1, 2015 at 7:13 AM, sercanerhan <sercanerhan@anonymised.com> wrote:
Hi Jose,
add
It works in debug mode, thank you. But, I still couldn't change the default
language.
Also, without debug mode, it doesn't work and it is not a cache issue
unfortunately :frowning:
I need to check sth more. Thank you so much again.
Sercan
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-3-0-1-language-selection-Combo-Box-tp5226775p5227282.html
The minified javascript and CSS is cached server-side. You need to remove
the wro4j cache if you want to get it working without the debug parameter.
Search for wro4j-cache.* in the GN data directory and remove the files
wro4j-cache.h2.db, wro4j-cache.lock.db and wro4j-cache.trace.db
Juan Luis.
On Thu, Oct 1, 2015 at 12:18 PM, sercanerhan <sercanerhan@anonymised.com> wrote:
Hi Juan Luis,
That's it! Thank you so much.
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-3-0-1-language-selection-Combo-Box-tp5226775p5227491.html
