[GeoNetwork-users] GeoNetwork 3.0.1 released
Dear all,
We're proud to announce the release of GeoNetwork opensource v3.0.1 (
http://geonetwork-opensource.org/). This is a minor release that includes
bug fixes discovered in earlier versions.
You can find the software at
https://sourceforge.net/projects/geonetwork/files/GeoNetwork_opensource/v3.0
.1/
You can find a list of changes in v3.0.1 at
*http://geonetwork-opensource.org/manuals/trunk/eng/users/overview/change-log/version-3.0.1.html
<http://geonetwork-opensource.org/manuals/trunk/eng/users/overview/change-log/version-3.0.1.html&gt;\*
If you have any improvements you want to contribute back, the best is to
use git to get a local copy of the source code, apply the fix and put out a
Pull request so your improvements can be integrated quickly. Otherwise you
can also create new Tickets in the issue tracker:
https://github.com/geonetwork/core-geonetwork/issues
Thanks and congratulations to the all community members and developers that
have been putting a huge amount of effort and energy in this release!
Francois Prunayre
PSC member
Hi Jim
2015-07-09 20:06 GMT+02:00 Jim Proctor <jproctor@anonymised.com>:
Congrats and many thanks! We are running GN on a Tomcat server: if I
simply deploy the .war file for 3.0.1, will it overwrite files (e.g.,
modified templates) in the geonetwork directory?
Templates are stored in the database.
Before any updates, it's recommended to backup:
* the database
* the data directory
* the webapp
Check the information panel to see where are located each resources:
http://localhost:8080/geonetwork/srv/eng/admin.console#/dashboard/information
Then you can update the WAR and it will run the migration which is pretty
simple from 3.0.0 to 3.0.1
See
https://github.com/geonetwork/core-geonetwork/blob/3.0.x/web/src/main/webapp/WEB-INF/classes/setup/sql/migrate/v301/migrate-default.sql
You can also apply it manually on the database and then start the app.
HTH.
Francois
Jim P.
  James D. Proctor
<https://college.lclark.edu/faculty/members/james_proctor/&gt;, Professor &
Director
Environmental Studies Program
<https://college.lclark.edu/programs/environmental_studies/&gt;
348 JR Howard Hall
  Lewis & Clark College <https://www.lclark.edu>
0615 SW Palatine Hill Road, MSC 62
Portland, OR 97219
503.768.7707
On July 9, 2015 at 03:45:42, Francois Prunayre (fx.prunayre@anonymised.com)
wrote:
Dear all,
.1/
a
that
Francois Prunayre
PSC member
Don't Limit Your Business. Reach for the Cloud.
GigeNET's Cloud Solutions provide you with the tools and support that
you need to offload your IT needs and focus on growing your business.
Configured For All Businesses. Start Your Cloud Today.
https://www.gigenetcloud.com/
GeoNetwork-users mailing list
