how can I add a search field (i.e. Temporal Extent) to advanced search panel in my geonetwork 3.0.3 installation; in previous versions (2.xx) the field was in the "When" section in the Advanced search.
Thanks in advance.
Teresa Fazio
Technical Specialist
Government & Security SBU
Planetek Italia s.r.l.
Via Massaua 12, I-70132 Bari
Tel.: +39 080 9644200 - Fax: +39 080 9644299
fazio@anonymised.com - http://www.planetek.it
Ok, but the "When" advanced panel search only for Creation and modification
dates, not for temporal extent date.
I find solution adding this div to searchForm.html file
<div data-gn-period-chooser="tempExtentBegin"
data-date-from="searchObj.params.extFrom"
data-date-to="searchObj.params.extTo">
</div>
Even if it adds a new search field
<http://osgeo-org.1560.x6.nabble.com/file/n5264669/Untitled.png>
and it constructs correctly the query
<http://osgeo-org.1560.x6.nabble.com/file/n5264669/Untitled1.png>
Query results are wrong.
Perhaps are there problems on date format?
Can you help me?
Thanks in advance.
Teresa Fazio
View this message in context: http://osgeo-org.1560.x6.nabble.com/geonetwork-3-0-3-add-fields-to-advanced-search-panel-tp5264102p5264669.html
It is working here, probably some problems with date format or something like
that.
<http://osgeo-org.1560.x6.nabble.com/file/n5264680/TbmOro8.png>
View this message in context: http://osgeo-org.1560.x6.nabble.com/geonetwork-3-0-3-add-fields-to-advanced-search-panel-tp5264102p5264680.html
Can you tell me your geonetwork version please?
I'm using 3.0.4.
View this message in context: http://osgeo-org.1560.x6.nabble.com/geonetwork-3-0-3-add-fields-to-advanced-search-panel-tp5264102p5264690.html
Did you have to add tempExtentBegin and tempExtentEnd to config-lucene.xml
file?
<tokenized>
<Field name="any"/>
<Field name="anylight"/>
<Field name="abstract"/>
<Field name="title"/>
<Field name="altTitle"/>
<Field name="keywordType"/>
<Field name="orgName"/>
<Field name="specificationTitle"/>
<Field name="levelName"/>
<Field name="subject"/>
* <Field name="tempExtentBegin"/>
<Field name="tempExtentEnd"/>*
</tokenized>
View this message in context: http://osgeo-org.1560.x6.nabble.com/geonetwork-3-0-3-add-fields-to-advanced-search-panel-tp5264102p5264725.html
I have tempExtentBegin in config-lucene (I think this is default), but only
in <dumpFields> section, not in <tokenized>
View this message in context: http://osgeo-org.1560.x6.nabble.com/geonetwork-3-0-3-add-fields-to-advanced-search-panel-tp5264102p5264726.html
