Hi
Has someone succeed in setting up postgis for the spatial indexing in
GeoNetwork 3?
I'm enabling JNDI for this, but I get the following error on startup:
2016-01-28 12:02:30,543 INFO [geonetwork.databasemigration] - -
Migration ...
2016-01-28 12:02:30,736 INFO [geonetwork.databasemigration] - Error
getting database version: ERROR: relation "settings" does not exist
Position: 19. Probably due to an old version. Trying with new Settings
structure.
2016-01-28 12:02:30,737 INFO [geonetwork.databasemigration] - Webapp
version:3.0.4-SNAPSHOT subversion:SNAPSHOT
Database version:null subversion:null
2016-01-28 12:02:30,737 WARN [geonetwork.databasemigration] -
Database does not contain any version information. Check that the database
is a GeoNetwork database with data. The database is probably empty, no
migration required.
org.springframework.beans.factory.BeanCreationException: Error creating
bean with name 'entityManagerFactory' defined in URL
[jar:file:/usr/local/apache-tomcat-7.0.67/webapps/geonetwork/WEB-INF/lib/domain-3.0.4-SNAPSHOT.jar!/config-spring-geonetwork.xml]:
Cannot resolve reference to bean 'jpaVendorAdapter' while setting bean
property 'jpaVendorAdapter'; nested exception is
bean with name 'jpaVendorAdapter' defined in URL
Cannot resolve reference to bean 'jpaVendorAdapterDatabaseParam' while
setting bean property 'database'; nested exception is
org.springframework.beans.factory.NoSuchBeanDefinitionException: No bean
named 'jpaVendorAdapterDatabaseParam' is defined
at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:329)
at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:107)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1417)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1158)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:458)
at
org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:296)
at
org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:223)
at
org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:293)
at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:194)
at
org.springframework.context.support.AbstractApplicationContext.getBean(AbstractApplicationContext.java:1117)
at
org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:922)
at
org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:479)
at
jeeves.config.springutil.JeevesContextLoaderListener.contextInitialized(JeevesContextLoaderListener.java:56)
*Changes done:*
*TOMCAT_DIR/webapps/geonetwork/WEB-INF/config-node/srv.xml*
<!-- <import resource="../config-db/h2.xml"/> -->
<import resource="../config-db/jndi-postgres-postgis.xml"/>
<!--<import resource="../config-db/oracle.xml"/>-->
<!--<import resource="../config-db/mysql.xml"/> -->
<!--<import resource="../config-db/db2.xml"/> -->
<!--<import resource="../config-db/postgres.xml"/>-->
<!--<import resource="../config-db/sqlserver.xml"/> -->
*TOMCAT_DIR/webapps/geonetwork/WEB-INF/config-db/**jndi-postgres-postgis.xml*
<bean id="jdbcDataSource"
class="org.springframework.jndi.JndiObjectFactoryBean">
<property name="jndiName" value="java:/comp/env/jdbc/geonetwork"/>
<property name="cache" value="true"/>
<property name="exposeAccessContext" value="false"/>
</bean>
*TOMCAT_DIR/conf/context.xml*
*<Resource name="jdbc/geonetwork" auth="Container"
type="javax.sql.DataSource"
username="geonetwork" password="XXXXX"
factory="org.apache.commons.dbcp.BasicDataSourceFactory"
driverClassName="org.postgis.DriverWrapper"
url="jdbc:postgresql_postGIS://localhost:5432/gn-postgis"
maxActive="10" maxIdle="10"
removeAbandoned="true"
removeAbandonedTimeout="3600" logAbandoned="true"
testOnBorrow="true"
defaultAutoCommit="false" validationQuery="SELECT
1" accessToUnderlyingConnectionAllowed="true"
In previous versions used to work following the steps described in the
manual, but for version 3 there's no documentation about this.
Wondering if I'm missing or wrong configuration?
Jose García
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/>Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv>
<https://twitter.com/geocat_bv>
<https://plus.google.com/u/1/+GeocatNetbv/posts>Please consider the
environment before printing this email.*
