[GeoNetwork-users] GeoNetwork 3.10.4 released
Dear all,
We're proud to announce the release of GeoNetwork opensource v3.10.4 (
http://geonetwork-opensource.org/).
You can find the software at https://sourceforge.net/projects/geonetwork
/files/GeoNetwork_opensource/v3.10.4/
You can find a list of new functionalities and fixes in v3.10.4 at
https://geonetwork-opensource.org/manuals/trunk/en/overview/change-log/version-3.10.4.html
If you have any improvements you want to contribute back, the best is to
use git to get a local copy of the source code, apply the fix and put out a
Pull request so your improvements can be integrated quickly. Otherwise you
can also create new Tickets in the issue tracker:
https://github.com/geonetwork/core-geonetwork/issues
Thanks and congratulations to the all community members and developers that
have been putting efforts and energy in this release!
Jose García
PSC Member
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>Please consider the environment before printing
this email.*
Hi Jody
Thanks for the feedback, I'll update the scripts to remove the -0 suffix
for the 3.10.5 version.
Jose García
On Sat, Oct 3, 2020 at 12:46 AM Jody Garnett <jody.garnett@anonymised.com> wrote:
Congratulations on the release!
I was going to offer to deploy the release to repo.osgeo.org but I see it
is already done, and am surprised at the version number used:
<dependency>
  <groupId>org.geonetwork-opensource</groupId>
  <artifactId>domain</artifactId>
  <version>3.10.4-0</version>
</dependency>
I understood the point of using *3.10.4-SNAPSHOT* was to make the next
*3.10.4* release, the use of 3.10.4*-0* forces maven to treat the version
number as a string.
3.10.0-0
3.10.1-0
3.10.2-0
3.10.3-0
3.10.4-0
3.6.0-0
3.8.0-0
(3.8.1 tag is 3.8.2-SNAPSHOT)
(3.8.2 tag is actually 3.8.3-SNAPSHOT)
3.8.3-0
4.0.0-alpha.3
In the above list 3.10.4-0 should be listed after 3.8.3-0 but because it
is being compared as a string it shows up in the wrong order.
In the future can I recommend removing the "-SNAPSHOT" when making a
release, so *3.10.4-SNAPSHOT* becomes *3.10.4 *on release.
Jody Garnett
On Thu, 1 Oct 2020 at 06:53, Jose Garcia <jose.garcia@anonymised.com> wrote:
Dear all,
that have been putting efforts and energy in this release!
Jose García
PSC Member
this email.*
GeoNetwork-devel mailing list
this email.*
Dear Jose, all,
Congratulations for the release!
Can someone please update the OSGeoLive installer for this new release?
https://github.com/OSGeo/OSGeoLive/blob/master/bin/install_geonetwork.sh
Best regards,
Angelos
On 10/1/20 4:26 PM, Jose Garcia wrote:
Dear all,
Jose García
PSC Member
Angelos Tzotsos, PhD
President
Open Source Geospatial Foundation
http://users.ntua.gr/tzotsos
I was going to offer to deploy the release to repo.osgeo.org but I see it is already done, and am surprised at the version number used:
domain
3.10.4-0
I understood the point of using 3.10.4-SNAPSHOT was to make the next 3.10.4 release, the use of 3.10.4**-0** forces maven to treat the version number as a string.
3.10.0-0
3.10.1-0
3.10.2-0
3.10.3-0
3.10.4-0
3.6.0-0
3.8.0-0
3.8.3-0
4.0.0-alpha.3
In the above list 3.10.4-0 should be listed after 3.8.3-0 but because it is being compared as a string it shows up in the wrong order.
In the future can I recommend removing the “-SNAPSHOT” when making a release, so 3.10.4-SNAPSHOT becomes 3.10.4 on release.
Jody Garnett
I wanted to add to this release … with the first formal release of iso191319.ca.HNAP:
See the above release announcement crediting those who contributed, following the core-geonetwork example.
Jody Garnett
Hi Jose:
I setup two PRs with this change for you:
This change means that downstream projects can continue to compile against the master or 3.10.x branch and not have to be updated each time a release is made.
I also double checked my research, and found a new article which actually tested with unit tests what maven does for both version definition and sort order, rather than trust the documentation!
It is worth reading, I was not aware how complicated it is!
  • If I understand this document correctly your previous ..- would indeed define okay
  • the difference between . and _ is ignored during sorting
  • It also indicates that 3.10.0 and 3.10.0-0 are sorted exactly the same!
  • And 4.0-alpha and 4.0a are aliases and also sort exactly the same
Jody
On Sun, 4 Oct 2020 at 22:53, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Jody
Thanks for the feedback, I’ll update the scripts to remove the -0 suffix for the 3.10.5 version.
Jose García
domain
3.10.4-0
3.10.0-0
3.10.1-0
3.10.2-0
3.10.3-0
3.10.4-0
3.6.0-0
3.8.0-0
3.8.3-0
4.0.0-alpha.3
Jody Garnett
Dear all,
We’re proud to announce the release of GeoNetwork opensource v3.10.4 (http://geonetwork-opensource.org/).
You can find the software at https://sourceforge.net/projects/geonetwork/files/GeoNetwork_opensource/v3.10.4/
You can find a list of new functionalities and fixes in v3.10.4 at https://geonetwork-opensource.org/manuals/trunk/en/overview/change-log/version-3.10.4.html
If you have any improvements you want to contribute back, the best is to use git to get a local copy of the source code, apply the fix and put out a Pull request so your improvements can be integrated quickly. Otherwise you can also create new Tickets in the issue tracker:
Thanks and congratulations to the all community members and developers that have been putting efforts and energy in this release!
Jose García
PSC Member
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
