[GeoNetwork-users] Geonetwork 3.2.1 : change metadata owner impossible
Hi
We have migrated since 3 weeks ago from 3.0.4 to 3.2.1 and now we have
some problems to change the owner of some metadatas.
I'm metadata administrator and when I want to change the owner of a
metadata, in geonetwork log, theses messages are returned :
2017-03-09 16:45:41,790 DEBUG
[org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerMapping]
- Looking up handlr method for path /api/records/e101/ownership
2017-03-09 16:45:41,792 DEBUG
- Returning handle method [public
org.fao.geonet.api.processing.report.MetadataProcessingReport
org.fao.geonet.api.records.MetadataSharingApi.setRecordwnership(java.lang.String,java.lang.Integer,java.lang.Integer,javax.servlet.http.HttpSession,javax.servlet.http.HttpServletRequest)
trows java.lang.Exception]
2017-03-09 16:45:41,796 DEBUG
[org.springframework.web.servlet.mvc.method.annotation.ExceptionHandlerExceptionResolver]
- Resolving eception from handler [public
org.fao.geonet.api.records.MetadataSharingpi.setRecordOwnership(java.lang.String,java.lang.Integer,java.lang.Integer,javax.servlet.http.HttpSession,javax.servlet.http.HttpServetRequest)
throws java.lang.Exception]:
org.fao.geonet.api.exception.ResourceNotFoundException: Record with UUID
'e101' not found in his catalog
- Invoking @EceptionHandler method: public org.fao.geonet.api.ApiError
org.fao.geonet.api.GlobalExceptionController.resourceNotFoundHandler(javax.ervlet.http.HttpServletRequest,java.lang.Exception)
2017-03-09 16:45:41,799 DEBUG
[org.springframework.web.servlet.mvc.method.annotation.RequestResponseBodyMethodProcessor]
- Written [og.fao.geonet.api.ApiError@anonymised.com] as
"application/json;charset=UTF-8" using
[org.springframework.http.converter.json.MappingJacksonHttpMessageConverter@anonymised.com
The status request :
URL de la requête :
<host>/geonetwork/srv/api/records/e101/ownership?userIdentifier=13&groupIdentifier=9493
Méthode de la requête : PUT
Code d'état : HTTP/1.1 404 Not Found
User et group identifiers exist in database.
Do you have any ideas about what is wrong, why 'record with uuid 'e101'
not found, I think it should be uuid metadata instead ?
Thanks
Annick
Hi Annick,
This is now fixed https://github.com/geonetwork/core-geonetwork/issues/1929
You can apply the changes in your local install and clear the JS cache
from the admin.
HTH
Francois
2017-03-10 11:15 GMT+01:00 Annick Battais <annick.battais@anonymised.com>:
Hi
URL de la requête :
Thanks
Annick
Announcing the Oxford Dictionaries API! The API offers world-renowned
dictionary content that is easy and intuitive to access. Sign up for an
account today to start using our lexical data to power your apps and
projects. Get started today and enter our developer competition.
http://sdm.link/oxford
GeoNetwork-users mailing list
