[GeoNetwork-users] Geonetwork 3.2.1 : editing some metadata cause layout.xsl error
We have problems when editing some metadata, nothing is written and we
have these messages in Log.
We have migrated from 3.0.4 to 3.2.1 but I don't know if there is a
relation between this problem and the migration.
I try to look the differences between xml description of 2 metadatas,
one ok and the other not, but It's difficult to find where is the
problem. Maybe the file layout.xsl is not good for some metadatas, I
really don't know XSL process.
Any idea about what it's going wrong ? just to guide us about what to do.
Thanks
Annick
2017-03-14 15:56:46,193 DEBUG
[org.springframework.web.servlet.mvc.support.DefaultHandlerExceptionResolver]
- Resolving exception from handler [public org.jdom.Element
org.fao.geonet.api.records.editing.MetadataEditingApi.startEditing(java.lang.String,java.lang.String,boolean,javax.servlet.http.HttpSession,java.util.Map<java.lang.String,
java.lang.String>,javax.servlet.http.HttpServletRequest) throws
java.lang.Exception]: net.sf.saxon.trans.XPathException: A sequence of
more than one item is not allowed as the value of parameter $label
(<label/>, <description/>)
2017-03-14 15:56:46,193 ERROR [jeeves] - Error occurred within a transaction
; SystemID:
file:///var/lib/geonetwork/instance1/data/config/schema_plugins/iso19139//layout/layout.xsl;
Line#: 526; Column#: -1
net.sf.saxon.trans.XPathException: A sequence of more than one item is
not allowed as the value of parameter $label (<label/>, <description/>)
        at net.sf.saxon.expr.Expression.typeError(Expression.java:981)
        at
net.sf.saxon.expr.CardinalityChecker.evaluateItem(CardinalityChecker.java:270)
        at
net.sf.saxon.expr.ExpressionTool.evaluate(ExpressionTool.java:296)
        at
net.sf.saxon.instruct.GeneralVariable.getSelectValue(GeneralVariable.java:374)
        at
net.sf.saxon.instruct.Instruction.assembleParams(Instruction.java:147)
        at
net.sf.saxon.instruct.CallTemplate.processLeavingTail(CallTemplate.java:291)
        at
net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:557)
        at
net.sf.saxon.instruct.Template.applyLeavingTail(Template.java:203)
        at
net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:345)
        at
net.sf.saxon.instruct.ApplyTemplates$ApplyTemplatesPackage.processLeavingTail(ApplyTemplates.java:527)
        at
net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:317)
        at
        at
        at
net.sf.saxon.instruct.ApplyTemplates.apply(ApplyTemplates.java:210)
        at
net.sf.saxon.instruct.ApplyTemplates.process(ApplyTemplates.java:170)
        at
net.sf.saxon.instruct.DocumentInstr.evaluateItem(DocumentInstr.java:278)
        at
        at
        at
        at
        at
        at net.sf.saxon.instruct.Block.processLeavingTail(Block.java:556)
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at net.sf.saxon.instruct.CallTemplate.process(CallTemplate.java:259)
        at
net.sf.saxon.instruct.CallTemplate.processLeavingTail(CallTemplate.java:281)
        at
        at net.sf.saxon.instruct.Choose.processLeavingTail(Choose.java:686)
        at net.sf.saxon.instruct.Instruction.process(Instruction.java:93)
        at net.sf.saxon.expr.LetExpression.process(LetExpression.java:378)
        at
net.sf.saxon.instruct.ForEach.processLeavingTail(ForEach.java:321)
        at
        at
        at
        at
        at
        at
        at
net.sf.saxon.instruct.ApplyTemplates.processLeavingTail(ApplyTemplates.java:174)
        at
net.sf.saxon.instruct.ElementCreator.processLeavingTail(ElementCreator.java:296)
        at
        at
        at net.sf.saxon.Controller.transformDocument(Controller.java:1807)
        at net.sf.saxon.Controller.transform(Controller.java:1621)
        at org.fao.geonet.utils.Xml.transform(Xml.java:492)
        at org.fao.geonet.utils.Xml.transform(Xml.java:364)
        at
org.fao.geonet.api.records.editing.MetadataEditingApi.buildEditorForm(MetadataEditingApi.java:698)
        at
org.fao.geonet.api.records.editing.MetadataEditingApi.startEditing(MetadataEditingApi.java:162)
        at
org.fao.geonet.api.records.editing.MetadataEditingApi$$FastClassBySpringCGLIB$$363e745.invoke(<generated>)
        at
org.springframework.cglib.proxy.MethodProxy.invoke(MethodProxy.java:204)
        at
org.springframework.aop.framework.CglibAopProxy$CglibMethodInvocation.invokeJoinpoint(CglibAopProxy.java:720)
        at
org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:157)
        at
org.springframework.security.access.intercept.aopalliance.MethodSecurityInterceptor.invoke(MethodSecurityInterceptor.java:64)
        at
org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
        at
org.springframework.aop.framework.CglibAopProxy$DynamicAdvisedInterceptor.intercept(CglibAopProxy.java:655)
        at
org.fao.geonet.api.records.editing.MetadataEditingApi$$EnhancerBySpringCGLIB$$fa6c6184.startEditing(<generated>)
        at sun.reflect.GeneratedMethodAccessor701.invoke(Unknown Source)
        at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.lang.reflect.Method.invoke(Method.java:498)
        at
org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:222)
        at
org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:137)
        at
org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:110)
        at
org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:814)
        at
org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:737)
        at
org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:85)
        at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
        at
jeeves.config.springutil.JeevesDispatcherServlet.access$001(JeevesDispatcherServlet.java:41)
        at
jeeves.config.springutil.JeevesDispatcherServlet$1.doInTransaction(JeevesDispatcherServlet.java:54)
        at
jeeves.config.springutil.JeevesDispatcherServlet$1.doInTransaction(JeevesDispatcherServlet.java:51)
        at
jeeves.transaction.TransactionManager.runInTransaction(TransactionManager.java:73)
        at
jeeves.config.springutil.JeevesDispatcherServlet.doDispatch(JeevesDispatcherServlet.java:48)
        at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
        at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:969)
        at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:860)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:618)
        at
org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:845)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:725)
        at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291)
        at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
        at
org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
        at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239)
        at
        at
org.fao.geonet.web.CORSResponseFilter.doFilter(CORSResponseFilter.java:128)
        at
        at
        at
org.fao.geonet.monitor.webapp.WebappMetricsFilter.doFilter(WebappMetricsFilter.java:121)
        at
        at
        at
org.fao.geonet.monitor.webapp.MetricsRegistryInitializerFilter.doFilter(MetricsRegistryInitializerFilter.java:58)
        at
        at
        at
org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
        at
org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
        at
org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
        at
org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:381)
        at
        at
        at
org.geonetwork.http.SessionTimeoutCookieFilter.doFilter(SessionTimeoutCookieFilter.java:89)
        at
        at
        at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
        at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:118)
        at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:84)
        at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342)
        at
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
        at
        at
org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:103)
        at
        at
org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:113)
        at
        at
org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:45)
        at
        at
org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:199)
        at
        at
org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
        at
        at
org.springframework.security.web.authentication.preauth.AbstractPreAuthenticatedProcessingFilter.doFilter(AbstractPreAuthenticatedProcessingFilter.java:94)
        at
        at
jeeves.config.springutil.MultiNodeAuthenticationFilter.doFilter(MultiNodeAuthenticationFilter.java:125)
        at
        at
org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:110)
        at
        at
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
        at
        at
org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:192)
        at
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:160)
        at
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
        at
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
        at
jeeves.config.springutil.JeevesDelegatingFilterProxy.doFilter(JeevesDelegatingFilterProxy.java:104)
        at
        at
        at
org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
        at
org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
        at
        at
        at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:219)
        at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
        at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:142)
        at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
        at
org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:610)
        at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
        at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:537)
        at
org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1081)
        at
org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:658)
        at
org.apache.coyote.http11.Http11NioProtocol$Http11ConnectionHandler.process(Http11NioProtocol.java:222)
        at
org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1566)
        at
org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1523)
        at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
        at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
        at
org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
        at java.lang.Thread.run(Thread.java:745)
Hi
Which metadata view are you using that has the problem: Default, INSPIRE?
Do you have any customisations in labels.xml file? Usually that kind of
errors happen if a label is duplicated in the labels.xml, but I found
similar issues in other cases.
Jose García
On Tue, Mar 14, 2017 at 4:16 PM, Annick Battais <
annick.battais@anonymised.com> wrote:
Thanks
Annick
transaction
; SystemID:
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
java:686)
        at
        at
        at
java:686)
        at
java:686)
        at
        at
        at
        at
java:686)
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
java:737)
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
176)
        at
        at
java:92)
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
java:113)
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
TaskThread.java:61)
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
We find that all metadatas with edit problem use this tag in xml
description in <gmd:dataQualityInfo> :
                <gml:BaseUnit gml:id="N102CE">
                  <gml:identifier codeSpace="">metres</gml:identifier>
                  <gml:unitsSystem gml:remoteSchema="" />
                </gml:BaseUnit>
I think It's no longer supported. I don't know when this problem
appeared but it seems not to be linked to migration to geonetwork 3.2.1.
Thanks a lot for guiding me.
Annick
Le 14/03/2017 à 16:24, Jose Garcia a écrit :
Hi
Jose García
<annick.battais@anonymised.com <mailto:annick.battais@anonymised.com>>
wrote:
    to do.
    Thanks
    Annick
    transaction
    ; SystemID:
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
            at
    <http://org.apache.tomcat.util.net>.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1566)
            at
    <http://org.apache.tomcat.util.net>.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1523)
            at
            at
            at
    <mailto:GeoNetwork-users@lists.sourceforge.net>
    <https://lists.sourceforge.net/lists/listinfo/geonetwork-users&gt;
    <http://sourceforge.net/projects/geonetwork&gt;
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664 <tel:+31318416664>
<https://www.facebook.com/geocatbv&gt; <https://twitter.com/geocat_bv&gt; <https://plus.google.com/u/1/+GeocatNetbv/posts&gt;
Please consider the environment before printing this email.
