[GeoNetwork-users] GeoNetwork 3.2.2 released
Dear all,
We're proud to announce the release of GeoNetwork opensource v3.2.2(
http://geonetwork-opensource.org/). This is a maintenance release for the
project.
You can find the software at
https://sourceforge.net/projects/geonetwork/files/GeoNetwork
_opensource/v3.2.2/
You can find a list of new functionalities and fixes in v3.2.2 at
http://geonetwork-opensource.org/manuals/trunk/
eng/users/overview/change-log/version-3.2.2.html
If you have any improvements you want to contribute back, the best is to
use git to get a local copy of the source code, apply the fix and put out a
Pull request so your improvements can be integrated quickly. Otherwise you
can also create new Tickets in the issue tracker:
https://github.com/geonetwork/core-geonetwork/issues
Thanks and congratulations to the all community members and developers that
have been putting efforts and energy in this release!
*IMPORTANT NOTE FOR UPGRADING FROM PREVIOUS 3.x VERSIONS WITH EXTERNAL DATA
DIRECTORY*
If you use the default data directory in GeoNetwork, you can skip this note.
For those that are upgrading from a previous 3.x version and have
customised the data directory in a external folder (
http://geonetwork-opensource.org/manuals/trunk/eng/users/maintainer-guide/installing/customizing-data-directory.html),
before
starting up this new version you need to remove manually the old wro4j
cache files, otherwise will get the following exception:
    *Invalid CSRF Token '' was found on the request parameter '_csrf' or
header 'X-XSRF-TOKEN'.*
Please, search for the files (*wro4j-cache.h2.db*, *wro4j-cache.lock.db*)
in your data directory and remove them.
*This step should be done only once, before upgrading the version.*
Apologies for this inconvenience.
Jose García
PSC member
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
