[GeoNetwork-users] Geonetwork 3.4.3 metadata ISO19139-3
Is there anybody using GEONETWORK 3.4.3 version with the new ISO19139-3 standard?
If so is it working properly or not? If it is working can someone attach a template of a working .xml metadata?
Thanks in advance
Bartolomeo
Le mer. 3 avr. 2019 à 15:09, Ventura Bartolomeo <
bartolomeo.ventura@anonymised.com> a écrit :
standard?
ISO19115-3 is only maintained on latest GeoNetwork version for now. Some
old branches may be working with 3.4 but are not updated anymore. Note also
that
https://github.com/metadata101/iso19115-3
is now replaced by
https://github.com/metadata101/iso19115-3.2018
which contains last version of the schema.
Both schemas are used in production on different places (eg. Ifremer,
Walloon region).
You always have templates in
https://github.com/metadata101/iso19115-3.2018/tree/3.7.x/src/main/plugin/iso19115-3.2018/templates
to start working with.
Cheers.
Francois
Thanks in advance
Bartolomeo
GeoNetwork-users mailing list
Thanks for your answer. Actually, I started from one of these templates and I solved a series of error I got using GN 3.4.3 to have a fully validate metadata 19115-3.
The only remaining error is this one:
Constraints related to access and use Conditions applying to access and use is missing.
I do not know if it is related to the GN version or not.
To skip this doubt, I will update my geonetwork version to the latest one and I try to see if I will get the same error or not.
For completeness of information, I tried to validate the examples on that webpage and all of them are not validated because of errors on SCHEMA implementation and INSPIRE schema. I will repeat this operation with the latest GN also for those files.
I will let you know.
Bartolomeo
Sent: Friday, April 12, 2019 08:45
To: Ventura Bartolomeo <bartolomeo.ventura@...1518...>
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Geonetwork 3.4.3 metadata ISO19139-3
Le mer. 3 avr. 2019 à 15:09, Ventura Bartolomeo <bartolomeo.ventura@...1518...<mailto:bartolomeo.ventura@…1518…>> a écrit :
ISO19115-3 is only maintained on latest GeoNetwork version for now. Some old branches may be working with 3.4 but are not updated anymore. Note also that
is now replaced by
Both schemas are used in production on different places (eg. Ifremer, Walloon region).
You always have templates in https://github.com/metadata101/iso19115-3.2018/tree/3.7.x/src/main/plugin/iso19115-3.2018/templates to start working with.
Cheers.
Francois
Thanks in advance
Bartolomeo
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@lists.sourceforge.net>
Le ven. 12 avr. 2019 à 09:50, Ventura Bartolomeo <
*Constraints related to access and use** Conditions applying to access
and use is missing.*
Sounds related to that schematron rule
https://github.com/metadata101/iso19115-3.2018/blob/a1e4bb285cd57cc0aa34b98f902db110a0a32b7c/src/main/plugin/iso19115-3.2018/schematron/schematron-rules-inspire.sch#L623
You can try to do some check if the rule is correct or not.
Francois
Bartolomeo
*From:* Francois Prunayre <fx.prunayre@anonymised.com>
*Sent:* Friday, April 12, 2019 08:45
*To:* Ventura Bartolomeo <bartolomeo.ventura@anonymised.com>
*Cc:* geonetwork-users@lists.sourceforge.net
*Subject:* Re: [GeoNetwork-users] Geonetwork 3.4.3 metadata ISO19139-3
standard?
that
is now replaced by
Walloon region).
Cheers.
Francois
Thanks in advance
Bartolomeo
I'm trying to follow the steps for adding the plugin here
I cloned the ISO 19115-3:2018 schema plugin in the folder:
geonetwork\WEB-INF\data\data\resources\xml\schemas
But I can't perform the step where I should add the new module to the schema/pom.xml
Could you please tell me where I can find this pom.xml file?
I checked all the pom.xml files in the geonetwork folder but none of them contain the <modules> tag.
Could you also please confirm that the next two steps are referring to the following file?
webapps\geonetwork\META-INF\maven\org.geonetwork-opensource\web-app\pom.xml
Bartolomeo
-----Original Message-----
From: Ventura Bartolomeo <bartolomeo.ventura@...1518...>
Sent: Friday, April 12, 2019 09:51
To: Francois Prunayre <fx.prunayre@...54...>
Bartolomeo
is now replaced by
Cheers.
Francois
Thanks in advance
Bartolomeo
Hi Bartolomeo,
In the core-geonetwork folder (before compiling), there is a small shell script "add-schema.sh" that does everything for you :slight_smile:
When you are in the core-geonetwork folder, type in:
./add-schema.sh iso19115-3 https://github.com/metadata101/iso19115-3.2018 3.5.x
and you should be fine.
Nicolas
On 16/04/19 16:11, Ventura Bartolomeo wrote:
Bartolomeo
From: Ventura Bartolomeo <bartolomeo.ventura@...1518...><mailto:bartolomeo.ventura@…1518…>
To: Francois Prunayre <fx.prunayre@...54...><mailto:fx.prunayre@…54…>
Cc: geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@lists.sourceforge.net>
Bartolomeo
From: Francois Prunayre <fx.prunayre@...54...><mailto:fx.prunayre@…54…>
To: Ventura Bartolomeo <bartolomeo.ventura@...1518...><mailto:bartolomeo.ventura@…1518…>
Le mer. 3 avr. 2019 à 15:09, Ventura Bartolomeo <bartolomeo.ventura@...1518...<mailto:bartolomeo.ventura@…1518…><mailto:bartolomeo.ventura@…1518…><mailto:bartolomeo.ventura@…1518…>> a écrit :
is now replaced by
Cheers.
Francois
Thanks in advance
Bartolomeo
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@lists.sourceforge.net><mailto:GeoNetwork-users@lists.sourceforge.net><mailto:GeoNetwork-users@lists.sourceforge.net>
Nicolas de Ville
Belgian Marine Data Centre (BMDC)
OD-Nature, Royal Belgian Institute of Natural Sciences
02/627.42.79
www.bmdc.be<http://www.bmdc.be>
geonetwork.bmdc.be
Hi Bartolomeo,
3.5.x
Nicolas
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-users-f3860293.html
Le mar. 16 avr. 2019 à 16:48, Ndeville <ndeville@anonymised.com> a
écrit :
Hi Bartolomeo,
3.5.x
Mind that the schema id is iso19115-3.2018 and not iso19115-3. Note also
that this schema which includes 2018 amendment is still under development
and will only be supported on current GeoNetwork master branch (ie. 3.7.x+).
Francois
Nicolas
Sent from:
Hi Nicolas,
Thanks for your reply.
Do you mean I have to clone the entire core-geonetwork repository and then run the script?
Because now I'm using the geonetwork.war file to run geonetwork using tomcat9.
In my case, may not be enough to run the script? Am I right?
Thanks for your support and patience,
Cheer,
Bartolomeo
Sent: Tuesday, April 16, 2019 16:28
To: geonetwork-users@lists.sourceforge.net
Hi Bartolomeo,
3.5.x
Nicolas
A short update: using the .2018 schemas I got this error
mvn clean install -DskipTests
[INFO] Scanning for projects...
[ERROR] The build could not read 1 project -> [Help 1]
[ERROR]
[ERROR] The project org.geonetwork-opensource:schema-iso19115-3.2018:3.5 (/opt/tomcat/webapps/core-geonetwork/schemas/iso19115-3/pom.xml) has 1 error
[ERROR] Non-resolvable parent POM: Failure to find org.geonetwork-opensource:schemas:pom:3.5 in https://repo.maven.apache.org/maven2 was cached in the local repository, resolution will not be reattempted until the update interval of central has elapsed or updates are forced and 'parent.relativePath' points at wrong local POM @ line 6, column 10 -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/ProjectBuildingException
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/UnresolvableModelException
Maybe it could be useful to know
Bart
Sent: Tuesday, April 16, 2019 17:34
To: Ndeville <ndeville@...1741...>
Cc: Geonetwork-Users@...638...
Le mar. 16 avr. 2019 à 16:48, Ndeville <ndeville@...1741...> a écrit :
Hi Bartolomeo,
3.5.x
Mind that the schema id is iso19115-3.2018 and not iso19115-3. Note also that this schema which includes 2018 amendment is still under development and will only be supported on current GeoNetwork master branch (ie. 3.7.x+).
Francois
Nicolas
Sent from:
I also tried the iso19115-3 schema plugin but it does not work the maven cmd:
Downloading: https://repo.maven.apache.org/maven2/org/geonetwork-opensource/schemas/3.5/schemas-3.5.pom
[ERROR]
[ERROR] The project org.geonetwork-opensource:schema-iso19115-3:3.5 (/opt/tomcat/webapps/core-geonetwork/schemas/iso19115-3/pom.xml) has 1 error
[ERROR] Non-resolvable parent POM: Could not find artifact org.geonetwork-opensource:schemas:pom:3.5 in central (https://repo.maven.apache.org/maven2) and 'parent.relativePath' points at wrong local POM @ line 5, column 10 -> [Help 2]
[ERROR]
[ERROR]
Is The webpage not available any more.?
Thanks
Bart
Sent: Wednesday, April 17, 2019 07:41
To: Ndeville <ndeville@anonymised.com>; geonetwork-users@lists.sourceforge.net
Subject: RE: [GeoNetwork-users] Geonetwork 3.4.3 metadata ISO19139-3
Hi Nicolas,
Cheer,
Bartolomeo
Hi Bartolomeo,
3.5.x
Nicolas
