[GeoNetwork-users] GeoNetwork 3.8.0, 3.8.1, and in docker: [jeeves.service] - Service not found : md.formatter.list
Hello,
ERROR [jeeves.service] - Service not found : md.formatter.list
The error ocucrs in all 3.8 versions we have tried. I doe not occur in 3.6.0 We are fairly sure the error is not caused by anything in our GeoNetwork configuration.
Symptoms:
As administrator, when we go to the Admin Console → metadata & templates → formatter, no formatters are displayed and the error message appears in catalina.out.
The direct API request:
localhost:8080/geonetwork/src/eng/md/formatter.list?_content_type=json
gives a return code of 505.
Our analysis:
The 3.8.0, 3.8.1 and the docker version that was released along with 3.8.0 all have the error message and empty list. This is repeatable in 3 versions of Linux, with different tomcat versions, Oracle JDK and OpenJDK, postgres, and web browsers. It is repeatable using the default install and an empty database.
We have not been able to identify any changes in github code that we could identify is relevant. Our java experience is limited, so we probably missed something.
Questions:
  1. Can someone else replicate this to confirm that it is not something wrong at our location?
  2. Is there other information we can provide that would help
Thank you for any help.
Jeff
Jeffrey Campbell
On Thu, Oct 10, 2019 at 7:21 PM Jeff Campbell <
dev@anonymised.com> wrote:
Hello,
*Symptoms:*
As administrator, when we go to the *Admin Console -> metadata &
templates -> formatter*, no formatters are displayed and the error
*Our analysis:*
database.
something.
*Questions:*
For us, the URL called in that admin screen is
https://vanilla.geocat.net/geonetwork/srv/eng/md.formatter.list?_content_type=json
(3.8.x
branch)
and it returns a 500 error:
  "error": {
    "message":
        "Service not found",
    "class":
        "ServiceNotFoundEx,
    "request": {}
It's strange, because the class that manages the request hasn't changed
since 2017 [1].
[1]
https://github.com/geonetwork/core-geonetwork/blob/3.8.x/services/src/main/java/org/fao/geonet/api/records/formatters/ListFormatters.java#L106-L115
*Vriendelijke groeten / Kind regards,Juan Luis Rodríguez.
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>Please consider the environment before printing
this email.*
Hi Jeff,
On Tue, Oct 15, 2019 at 4:09 PM Juan Luis Rodríguez Ponce <
Hello,
*Symptoms:*
*Our analysis:*
an empty database.
missed something.
*Questions:*
https://vanilla.geocat.net/geonetwork/srv/eng/md.formatter.list?_content_type=json (3.8.x
branch)
  "error": {
    "message":
    "class":
        "ServiceNotFoundEx,
    "request": {}
since 2017 [1].
[1]
Problem has been fixed both in 3.8.x branch and master. You can patch your
source code with this commit [1], checkout 3.8.x branch and build the WAR
or try a 3.8.x nightly build WAR [2].
Thank you for reporting the bug.
[1]
https://github.com/geonetwork/core-geonetwork/commit/1199fd6fda45ff23429bbfbaab86898d9743b1c7
[2] http://nightlybuild.geonetwork-opensource.org/3.8.x/
this email.*
