Hello,
1. I have updated from geonetwork 2 to geonetwork 3 but I cannot see any map in the Full view. I don't want to switch back, because the new Frontend looks good.
I am in the view My Geonetwork catalogue / Full view.
I am using a sample metadata:
Refer to example: Localities in Victoria (VMADMIN.LOCALITY_POLYGON) - Comprehensive Elements
- Following exception is thrown (s.b.). How can I fix it?. Maybe you can give me some hints or configuration files for geonetwork3, which will fix that.
I have installed geoserver, too. Maybe I can reconfigure the setting.
2. How can I fix following error message Failed to translate codelist value 'boundaries' in language 'eng'. Error is null (Full exception s.b.)
3. I have following exception when I import a metadata record. But the import works well.
4. Is it possible to set the Full view in My Geonetwork catalogue / Full view to the standard view?
I have posted you all the exceptions from my tomcat log. I am using it with postgres 2.4. The most important thing is for me the issue 1 with the map. Maybe it can help you with the further development for geonetwork3, too.
Geonetwork 2.10 works, but I down want to step back. I will see if we can solve the issue with the map.
If you need more infos or files don't hesitate to contact me.
Olaf
To 1)
2015-06-24 14:58:56,894 WARN [geonetwork.resources] - Store file download request: No upload request for (metadataid, file): (40988,DMCII01_U2002af5_000000_015499_s_L2R_GLCF-PAN_SRTMv3.jpg)
2015-06-24 14:59:07,395 ERROR [jeeves] - Error occurred within a transaction
BadParameterEx : Either geom or id is required is not a valid value for: id
at org.fao.geonet.services.region.GetMap.exec(GetMap.java:187)
at sun.reflect.GeneratedMethodAccessor630.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.springframework.web.method.support.InvocableHandlerMethod.invoke(InvocableHandlerMethod.java:219)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:132)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:104)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandleMethod(RequestMappingHandlerAdapter.java:745)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:686)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:80)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:925)
at jeeves.config.springutil.JeevesDispatcherServlet.access$001(JeevesDispatcherServlet.java:17)
at jeeves.config.springutil.JeevesDispatcherServlet$1.doInTransaction(JeevesDispatcherServlet.java:30)
at jeeves.config.springutil.JeevesDispatcherServlet$1.doInTransaction(JeevesDispatcherServlet.java:27)
at jeeves.transaction.TransactionManager.runInTransaction(TransactionManager.java:63)
at jeeves.config.springutil.JeevesDispatcherServlet.doDispatch(JeevesDispatcherServlet.java:24)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:856)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:936)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:827)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:622)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:812)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239)
at org.fao.geonet.monitor.webapp.WebappMetricsFilter.doFilter(WebappMetricsFilter.java:96)
at org.fao.geonet.monitor.webapp.MetricsRegistryInitializerFilter.doFilter(MetricsRegistryInitializerFilter.java:31)
at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:381)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:118)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:84)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:103)
at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:113)
at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:45)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:183)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at jeeves.config.springutil.PassthroughFilter.doFilter(PassthroughFilter.java:26)
at jeeves.config.springutil.MultiNodeAuthenticationFilter.doFilter(MultiNodeAuthenticationFilter.java:98)
at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:105)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:192)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:160)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:343)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:260)
at jeeves.config.springutil.JeevesDelegatingFilterProxy.doFilter(JeevesDelegatingFilterProxy.java:64)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:219)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:142)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:610)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:518)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1091)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:668)
at org.apache.coyote.http11.Http11NioProtocol$Http11ConnectionHandler.process(Http11NioProtocol.java:223)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1517)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1474)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:722)
To 2)
2015-06-24 15:02:30,053 ERROR [geonetwork] - Failed to translate codelist value 'boundaries' in language 'eng'. Error is null
2015-06-24 15:02:30,056 ERROR [geonetwork] - Failed to translate codelist value 'utf8' in language 'eng'. Error is null
2015-06-24 15:02:30,056 ERROR [geonetwork] - Failed to translate codelist value 'dataset' in language 'eng'. Error is null
2015-06-24 15:02:30,057 ERROR [geonetwork] - Failed to translate codelist value 'custodian' in language 'eng'. Error is null
2015-06-24 15:02:30,057 ERROR [geonetwork] - Failed to translate codelist value 'revision' in language 'eng'. Error is null
2015-06-24 15:02:30,057 ERROR [geonetwork] - Failed to translate codelist value 'publication' in language 'eng'. Error is null
2015-06-24 15:02:30,058 ERROR [geonetwork] - Failed to translate codelist value 'mapDigital' in language 'eng'. Error is null
2015-06-24 15:02:30,058 ERROR [geonetwork] - Failed to translate codelist value 'onGoing' in language 'eng'. Error is null
2015-06-24 15:02:30,058 ERROR [geonetwork] - Failed to translate codelist value 'pointOfContact' in language 'eng'. Error is null
2015-06-24 15:02:30,059 ERROR [geonetwork] - Failed to translate codelist value 'fortnightly' in language 'eng'. Error is null
2015-06-24 15:02:30,059 ERROR [geonetwork] - Failed to translate codelist value 'dataset' in language 'eng'. Error is null
2015-06-24 15:02:30,059 ERROR [geonetwork] - Failed to translate codelist value 'theme' in language 'eng'. Error is null
2015-06-24 15:02:30,059 ERROR [geonetwork] - Failed to translate codelist value 'revision' in language 'eng'. Error is null
2015-06-24 15:02:30,060 ERROR [geonetwork] - Failed to translate codelist value 'custodian' in language 'eng'. Error is null
2015-06-24 15:02:30,060 ERROR [geonetwork] - Failed to translate codelist value 'documentDigital' in language 'eng'. Error is null
2015-06-24 15:02:30,060 ERROR [geonetwork] - Failed to translate codelist value 'intellectualPropertyRights' in language 'eng'. Error is null
2015-06-24 15:02:30,061 ERROR [geonetwork] - Failed to translate codelist value 'otherRestrictions' in language 'eng'. Error is null
2015-06-24 15:02:30,061 ERROR [geonetwork] - Failed to translate codelist value 'vector' in language 'eng'. Error is null
2015-06-24 15:02:30,061 ERROR [geonetwork] - Failed to translate codelist value 'revision' in language 'eng'. Error is null
2015-06-24 15:02:30,062 ERROR [geonetwork] - Failed to translate codelist value 'documentDigital' in language 'eng'. Error is null
2015-06-24 15:02:30,062 ERROR [geonetwork] - Failed to translate codelist value 'dataset' in language 'eng'. Error is null
2015-06-24 15:02:30,062 ERROR [geonetwork] - Failed to translate codelist value 'directInternal' in language 'eng'. Error is null
To 3)
gn-fn-metadata:getLabel | missing translation in schema iso19139 for gmd:lineage.
gn-fn-metadata:getLabel | missing translation in schema iso19139 for gco:nilReason.
gn-fn-metadata:getLabel | missing translation in schema iso19139 for gmd:language.
gn-fn-metadata:getLabel | missing translation in schema iso19139 for gmd:hierarchyLevel.
gn-fn-metadata:getLabel | missing translation in schema iso19139 for gmd:hierarchyLevelName.
2015-06-24 14:58:21,311 WARN [org.springframework.context.support.ResourceBundleMessageSource] - ResourceBundle [messages] not found for MessageSource: Can't find bundle for base name messages, locale de
2015-06-24 14:58:21,313 WARN [org.springframework.context.support.ResourceBundleMessageSource] - ResourceBundle [messages] not found for MessageSource: Can't find bundle for base name messages, locale de
2015-06-24 14:58:21,539 ERROR [jeeves.resources] - Error cloning the cached data. Attempted to get: /var/lib/pgsql/apache-tomcat-8.0.21/webapps/geonetwork/loc/ger/xml/i18n.xmlbut failed so falling back to default language
2015-06-24 14:58:21,829 ERROR [jeeves.webapp.md.edit.saveonly] - Mail server host not configure
