[GeoNetwork-users] geonetwork 3 - map in full view does not work, other issues
Updated to geonetwork 3.1.0. Map is still not displayed in product 'Full view'.
Which files are involved for the map?
Regards
Olaf
Von: Olaf Scheidt
Gesendet: Mittwoch, 24. Juni 2015 17:24
An: 'geonetwork-users@lists.sourceforge.net'
Betreff: geonetwork 3 - map in full view does not work, other issues
Hello,
1. I have updated from geonetwork 2 to geonetwork 3 but I cannot see any map in the Full view. I don't want to switch back, because the new Frontend looks good.
I am in the view My Geonetwork catalogue / Full view.
I am using a sample metadata:
Refer to example: Localities in Victoria (VMADMIN.LOCALITY_POLYGON) - Comprehensive Elements
- Following exception is thrown (s.b.). How can I fix it?. Maybe you can give me some hints or configuration files for geonetwork3, which will fix that.
I have installed geoserver, too. Maybe I can reconfigure the setting.
2. How can I fix following error message Failed to translate codelist value 'boundaries' in language 'eng'. Error is null (Full exception s.b.)
3. I have following exception when I import a metadata record. But the import works well.
4. Is it possible to set the Full view in My Geonetwork catalogue / Full view to the standard view?
I have posted you all the exceptions from my tomcat log. I am using it with postgres 2.4. The most important thing is for me the issue 1 with the map. Maybe it can help you with the further development for geonetwork3, too.
Geonetwork 2.10 works, but I down want to step back. I will see if we can solve the issue with the map.
If you need more infos or files don't hesitate to contact me.
Olaf
To 1)
2015-06-24 14:58:56,894 WARN [geonetwork.resources] - Store file download request: No upload request for (metadataid, file): (40988,DMCII01_U2002af5_000000_015499_s_L2R_GLCF-PAN_SRTMv3.jpg)
2015-06-24 14:59:07,395 ERROR [jeeves] - Error occurred within a transaction
BadParameterEx : Either geom or id is required is not a valid value for: id
        at org.fao.geonet.services.region.GetMap.exec(GetMap.java:187)
        at sun.reflect.GeneratedMethodAccessor630.invoke(Unknown Source)
        at java.lang.reflect.Method.invoke(Method.java:601)
        at org.springframework.web.method.support.InvocableHandlerMethod.invoke(InvocableHandlerMethod.java:219)
        at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:132)
        at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:104)
        at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandleMethod(RequestMappingHandlerAdapter.java:745)
        at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:686)
        at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:80)
        at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:925)
        at jeeves.config.springutil.JeevesDispatcherServlet.access$001(JeevesDispatcherServlet.java:17)
        at jeeves.config.springutil.JeevesDispatcherServlet$1.doInTransaction(JeevesDispatcherServlet.java:30)
        at jeeves.config.springutil.JeevesDispatcherServlet$1.doInTransaction(JeevesDispatcherServlet.java:27)
        at jeeves.transaction.TransactionManager.runInTransaction(TransactionManager.java:63)
        at jeeves.config.springutil.JeevesDispatcherServlet.doDispatch(JeevesDispatcherServlet.java:24)
        at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:856)
        at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:936)
        at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:827)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:622)
        at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:812)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
        at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239)
        at org.fao.geonet.monitor.webapp.WebappMetricsFilter.doFilter(WebappMetricsFilter.java:96)
        at org.fao.geonet.monitor.webapp.MetricsRegistryInitializerFilter.doFilter(MetricsRegistryInitializerFilter.java:31)
        at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
        at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
        at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
        at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:381)
        at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
        at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:118)
        at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:84)
        at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342)
        at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
        at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:103)
        at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:113)
        at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:45)
       at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:183)
        at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
        at jeeves.config.springutil.PassthroughFilter.doFilter(PassthroughFilter.java:26)
        at jeeves.config.springutil.MultiNodeAuthenticationFilter.doFilter(MultiNodeAuthenticationFilter.java:98)
        at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:105)
        at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
        at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:192)
        at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:160)
        at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:343)
        at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:260)
        at jeeves.config.springutil.JeevesDelegatingFilterProxy.doFilter(JeevesDelegatingFilterProxy.java:64)
        at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
        at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:219)
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:142)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
       at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:610)
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:518)
        at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1091)
        at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:668)
        at org.apache.coyote.http11.Http11NioProtocol$Http11ConnectionHandler.process(Http11NioProtocol.java:223)
        at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1517)
        at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1474)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
        at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
        at java.lang.Thread.run(Thread.java:722)
To 2)
      2015-06-24 15:02:30,053 ERROR [geonetwork] - Failed to translate codelist value 'boundaries' in language 'eng'. Error is null
2015-06-24 15:02:30,056 ERROR [geonetwork] - Failed to translate codelist value 'utf8' in language 'eng'. Error is null
2015-06-24 15:02:30,056 ERROR [geonetwork] - Failed to translate codelist value 'dataset' in language 'eng'. Error is null
2015-06-24 15:02:30,057 ERROR [geonetwork] - Failed to translate codelist value 'custodian' in language 'eng'. Error is null
2015-06-24 15:02:30,057 ERROR [geonetwork] - Failed to translate codelist value 'revision' in language 'eng'. Error is null
2015-06-24 15:02:30,057 ERROR [geonetwork] - Failed to translate codelist value 'publication' in language 'eng'. Error is null
2015-06-24 15:02:30,058 ERROR [geonetwork] - Failed to translate codelist value 'mapDigital' in language 'eng'. Error is null
2015-06-24 15:02:30,058 ERROR [geonetwork] - Failed to translate codelist value 'onGoing' in language 'eng'. Error is null
2015-06-24 15:02:30,058 ERROR [geonetwork] - Failed to translate codelist value 'pointOfContact' in language 'eng'. Error is null
2015-06-24 15:02:30,059 ERROR [geonetwork] - Failed to translate codelist value 'fortnightly' in language 'eng'. Error is null
2015-06-24 15:02:30,059 ERROR [geonetwork] - Failed to translate codelist value 'dataset' in language 'eng'. Error is null
2015-06-24 15:02:30,059 ERROR [geonetwork] - Failed to translate codelist value 'theme' in language 'eng'. Error is null
2015-06-24 15:02:30,059 ERROR [geonetwork] - Failed to translate codelist value 'revision' in language 'eng'. Error is null
2015-06-24 15:02:30,060 ERROR [geonetwork] - Failed to translate codelist value 'custodian' in language 'eng'. Error is null
2015-06-24 15:02:30,060 ERROR [geonetwork] - Failed to translate codelist value 'documentDigital' in language 'eng'. Error is null
2015-06-24 15:02:30,060 ERROR [geonetwork] - Failed to translate codelist value 'intellectualPropertyRights' in language 'eng'. Error is null
2015-06-24 15:02:30,061 ERROR [geonetwork] - Failed to translate codelist value 'otherRestrictions' in language 'eng'. Error is null
2015-06-24 15:02:30,061 ERROR [geonetwork] - Failed to translate codelist value 'vector' in language 'eng'. Error is null
2015-06-24 15:02:30,061 ERROR [geonetwork] - Failed to translate codelist value 'revision' in language 'eng'. Error is null
2015-06-24 15:02:30,062 ERROR [geonetwork] - Failed to translate codelist value 'documentDigital' in language 'eng'. Error is null
2015-06-24 15:02:30,062 ERROR [geonetwork] - Failed to translate codelist value 'dataset' in language 'eng'. Error is null
2015-06-24 15:02:30,062 ERROR [geonetwork] - Failed to translate codelist value 'directInternal' in language 'eng'. Error is null
To 3)
gn-fn-metadata:getLabel | missing translation in schema iso19139 for gmd:lineage.
gn-fn-metadata:getLabel | missing translation in schema iso19139 for gco:nilReason.
gn-fn-metadata:getLabel | missing translation in schema iso19139 for gmd:language.
gn-fn-metadata:getLabel | missing translation in schema iso19139 for gmd:hierarchyLevel.
gn-fn-metadata:getLabel | missing translation in schema iso19139 for gmd:hierarchyLevelName.
2015-06-24 14:58:21,311 WARN [org.springframework.context.support.ResourceBundleMessageSource] - ResourceBundle [messages] not found for MessageSource: Can't find bundle for base name messages, locale de
2015-06-24 14:58:21,313 WARN [org.springframework.context.support.ResourceBundleMessageSource] - ResourceBundle [messages] not found for MessageSource: Can't find bundle for base name messages, locale de
2015-06-24 14:58:21,539 ERROR [jeeves.resources] - Error cloning the cached data. Attempted to get: /var/lib/pgsql/apache-tomcat-8.0.21/webapps/geonetwork/loc/ger/xml/i18n.xmlbut failed so falling back to default language
2015-06-24 14:58:21,829 ERROR [jeeves.webapp.md.edit.saveonly] - Mail server host not configure
There is no interactive map in the viewer, only an image with the bbox.
If you don't see it, something might be wrong in the metadata. try to use a
iso19139 metadata and set an extent.
There error you have in your logs tells it cannot get this image, probably
because it couldn't extract the geom.
Check there
https://github.com/geonetwork/core-geonetwork/blob/develop/schemas/iso19139/src/main/plugin/iso19139/formatter/groovy/iso19139/Handlers.groovy#L398
!image.png|614x589
Yes, but not with settings, you need to modify the default ui code, or
write your own ui view that manage the case you need.
Here an example where the full view is the only metadata view :
http://tc-geocat.dev.bgdi.ch/geonetwork/srv/eng/catalog.search
too.
Olaf
To 1)
transaction
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
       at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
       at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
To 2)
To 3)
gmd:lineage.
gco:nilReason.
gco:nilReason.
gmd:language.
gco:nilReason.
gmd:hierarchyLevel.
gco:nilReason.
Monitor 25 network devices or servers for free with OpManager!
OpManager is web-based network management software that monitors
network devices and physical & virtual servers, alerts via email & sms
for fault. Monitor 25 devices for free with no restriction. Download now
Download ManageEngine OpManager for Windows/Linux | 64 bit
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Florent Gravin
Camptocamp - Chambéry
0479444492
Hi Olaf
I have debug the 3.0.x branch (
https://github.com/geonetwork/core-geonetwork/tree/3.0.x) to check about
these errors:
And I don't get them, the translations are returned properly without errors.
So possibly has been fixed after the 3.0.0 release. In any case, to be
sure, are you using the default data directory in GeoNetwork or have you
customised to be configured in other path?
Jose García
On Mon, Jun 29, 2015 at 11:24 AM, Florent Gravin <
see
Check there
[image: Inline image 1]
the
> too.
> Regards,
> Olaf
> To 1)
download
> transaction
id
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> To 2)
> To 3)
> gmd:lineage.
> gco:nilReason.
> gco:nilReason.
> gmd:language.
> gco:nilReason.
> gmd:hierarchyLevel.
> gco:nilReason.
> http://ad.doubleclick.net/ddm/clk/292181274;119417398;o
> https://lists.sourceforge.net/lists/listinfo/geonetwork-users
> http://sourceforge.net/projects/geonetwork
Florent Gravin
0479444492
*GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net/&gt; for
details. _________________________Jose GarcíaGeoCat bvVeenderweg 136721 WD
BennekomThe Netherlandshttp://GeoCat.net/>*
