[GeoNetwork-users] Geonetwork and CKAN
Good Afternoon,
I would like someone to help me, where I can find some guidance to configure
GeoNetwork with CKAN for the harvesting.
Regards.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geonetwork-and-CKAN-tp5202183.html
it's not clear to me if CKAN should be harvesting from GeoNetwork, or vice
versa.
You can harvest GeoNetwork records from a CKAN instance using a CSW harvester
implemented in this extension:
    https://github.com/ckan/ckanext-spatial
If you need something GeoNetwork specific, such as mapping Geonetwork
categories into CKAN groups, you may want to use this harvester:
    https://github.com/geosolutions-it/ckanext-geonetwork
If you need to harvest CKAN datasets from GeoNetwork, you have to set up a CSW
harvester, pointing toward the CKAN CSW endpoint.
Remember that CKAN only offers for harvesting the datasets that have been
harvested from another CSW server.
Also refer to
   http://ckanext-spatial.readthedocs.org/en/latest/csw.html
   Emanuele
Alle 23:52:17 di Monday 20 April 2015, cbeltran ha scritto:
Good Afternoon,
configure GeoNetwork with CKAN for the harvesting.
Regards.
--- BPM Camp - Free Virtual Workshop May 6th at 10am PDT/1PM EDT
Develop your own process in accordance with the BPMN 2 standard
Learn Process modeling best practices with Bonita BPM through live
exercises http://www.bonitasoft.com/be-part-of-it/events/bpm-camp-virtual-
event?utm_
source=Sourceforge_BPM_Camp_5_6_15&utm_medium=email&utm_campaign=VA_SF
GeoNetwork-users mailing list
Ing. Emanuele Tajariol
Technical Lead
Via Poggio alle Viti 1187
mob: +39 380 2116282
Ciao Beltran,
some additional resources (may slightly outdated):
- here you can find some material we did use last year's FOSS4G to
talk about GN+CKAN+MapStore
http://geoserver.geo-solutions.it/downloads/training/windows/mapstore/
- this is some live doc about a similar integration we did last year
for a consortium of PAs in italy.
http://demo.geo-solutions.it/share/linea_comune/doc/online/index.html
Let me know if this is helpful or not :slight_smile:
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Tue, Apr 21, 2015 at 7:19 PM, Emanuele Tajariol <etj@anonymised.com> wrote:
versa.
Also refer to
   Emanuele
Good Afternoon,
Regards.
event?utm_
Technical Lead
Learn Process modeling best practices with Bonita BPM through live exercises
http://www.bonitasoft.com/be-part-of-it/events/bpm-camp-virtual- event?utm_
