[GeoNetwork-users] Geonetwork and Windows 7 64 Bit
I'm having some issues trying to install geonetwork on a standalone Windows 7 64 bit machine. I've tried installing it to both C:\Program Files and C:\Workspace without any luck. The installer completes successfully and it seems like the server starts, but then when I type in the address (or use the start menu shortcut) to start Geonetwork it comes up with an error saying it cannot find the correct page.
Anyone got any ideas?
Gavin Jackson
Spatial Data Analyst
Road and Traffic Engineering Branch
[cid:image001.jpg@anonymised.com]
Telephone: (08) 9323 4128
Email:gavin.jackson@anonymised.com
What's Perth traffic like today? www.twitter.com/perth_traffic
MAIN ROADS EMAIL DISCLAIMER
1. This email is confidential. If you are not the intended recipient, you must not disclose or use the information contained in it. If you have received this mail in error, please tell us immediately by return email and delete the document.
2. Any views expressed in this message are those of the individual sender, except where the sender specifically states them to be the views of Main Roads Western Australia.
3. Whilst this communication is believed to be free of any virus or defect, which may affect a computer or system into which it is received and opened, it is the responsibility of the recipient to ensure that it is virus free, and no responsibility is accepted by Main Roads Western Australia for any loss or damage arising, in any way, from its use.
(attachments)
What version are you installing? The .jar, .exe, or from source?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Geonetwork-and-Windows-7-64-Bit-tp6759705p6759792.html
I'm using version 2.6.4 exe direct from
http://sourceforge.net/projects/geonetwork/files/GeoNetwork_opensource/v2.6.4/
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Geonetwork-and-Windows-7-64-Bit-tp6759705p6759897.html
Do you have any other programs like Tomcat, other Jetty apps, or something
that might be using port 8080?
If open the GeoNetwork Start icon in the Task Manager Bar it will display
terminal window that shows the start up messages and communications with
GeoNetwork. This is a good place to look for clues.
Byron Cochrane
LISAsoft
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Geonetwork-and-Windows-7-64-Bit-tp6759705p6762074.html
Hi Byron,
Thanks for the reply. I don't have any programs using port 8080 on the machine I'm installing it on. Incidentally, I have also installed Geonetwork at work and our proxy uses port 8080. I'm assuming this will cause no end of difficulty for Geonetwork. Two questions arise from this:
1) On my standalone machine, I don't have any programs using port 8080 - any suggestions?
2) On my machine at work what do I need to do to allow geonetwork to use a different port?
Gavin
From: ByronCinNZ [via OSGeo.org] [mailto:ml-node+6762074-755181217-354739@anonymised.com]
Sent: Tuesday, 6 September 2011 5:15 AM
To: JACKSON Gavin (SDA)
Subject: Re: Geonetwork and Windows 7 64 Bit
Do you have any other programs like Tomcat, other Jetty apps, or something that might be using port 8080?
If open the GeoNetwork Start icon in the Task Manager Bar it will display terminal window that shows the start up messages and communications with GeoNetwork. This is a good place to look for clues.
Byron Cochrane
LISAsoft
If you reply to this email, your message will be added to the discussion below:
To unsubscribe from Geonetwork and Windows 7 64 Bit, click here<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=6759705&code=Z2F2aW4uamFja3NvbkBtYWlucm9hZHMud2EuZ292LmF1fDY3NTk3MDV8ODA0NTY2NzM4&gt;\.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Geonetwork-and-Windows-7-64-Bit-tp6759705p6762314.html
Hi Gavin,
when installing GeoNetwork/GeoServer on Windows Vista/7, you need to
run it with administrative rights or otherwise give it full read-write
permissions to the folders it's running from, otherwise it will not
work (it reads/writes stuff in those folders, not in the My Documents
area).
Victor
On Tue, Sep 6, 2011 at 2:43 AM, gavinjackson
<gavin.jackson@anonymised.com> wrote:
Hi Byron,
Gavin
Byron Cochrane
LISAsoft
Special Offer -- Download ArcSight Logger for FREE!
Finally, a world-class log management solution at an even better
price-free! And you'll get a free "Love Thy Logs" t-shirt when you
download Logger. Secure your free ArcSight Logger TODAY!
http://p.sf.net/sfu/arcsisghtdev2dev
GeoNetwork-users mailing list
Hmm, Victor's suggestion may be right but I would think that would only be a
problem when you installed it in Program Files. I would assume you have the
proper permissions to your workspace directory, but maybe not. Usually I
recommend installing GeoNetwork at C:\geonetwork (you need to create the
directory first in this case then tell the installer to overwrite). Try the
C:\workspace\geonetwork install again and take a look at the logfile -
C:\workspace\geonetwork\jetty\logs\geonetwork.log and see if there are any
error messages that might help.
One more thought - what version of Java are you using?
On the other topic, changing the servlet port, you can do this in the admin
interface, but of course you cannot access this. The way I usually do it is
by opening the file C:\workspace\geonetwork\bin\jetty.xml and edit the
following line:
<Set name="port"><SystemProperty name="jetty.port" default="8080"/></Set>
to
<Set name="port"><SystemProperty name="jetty.port" default="8088"/></Set>
Now GeoNetwork should come up on your own machine at
http:\\localhost:8088\geonetwork.
You might try changing the port just to test if this is the problem..
Byron Cochrane
LISAsoft
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Geonetwork-and-Windows-7-64-Bit-tp6759705p6765918.html
Hi Byron,
The changing of the port seems to have worked on my work machine (which has XP and the proxy port to access the internet was 8080 as well) so that was stopping geonetwork working. The other problem is that I couldn't change the jetty.xml file without administrative rights (just as installing the program needs as well) - will this affect any Geonetwork settings or creating metadata or viewing it?
As for my machine at home I shall try to install it in C:/Geonetwork and see what result I have.
Both machines (at work and at home) are running java version 1.6.0.
Gavin
From: ByronCinNZ [via OSGeo.org] [mailto:ml-node+6765918-702836977-354739@anonymised.com]
Sent: Wednesday, 7 September 2011 6:25 AM
Subject: RE: Geonetwork and Windows 7 64 Bit
Hmm, Victor's suggestion may be right but I would think that would only be a problem when you installed it in Program Files. I would assume you have the proper permissions to your workspace directory, but maybe not. Usually I recommend installing GeoNetwork at C:\geonetwork (you need to create the directory first in this case then tell the installer to overwrite). Try the C:\workspace\geonetwork install again and take a look at the logfile - C:\workspace\geonetwork\jetty\logs\geonetwork.log and see if there are any error messages that might help.
On the other topic, changing the servlet port, you can do this in the admin interface, but of course you cannot access this. The way I usually do it is by opening the file C:\workspace\geonetwork\bin\jetty.xml and edit the following line:
to
Now GeoNetwork should come up on your own machine at http:\\localhost:8088\geonetwork.
Byron Cochrane
LISAsoft
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Geonetwork-and-Windows-7-64-Bit-tp6759705p6774252.html
