[GeoNetwork-users] Geonetwork as local data catalog?
I'm new to Geonetwork, and just trying to get my head around whether
or not it fits my use case, or if I'm mistakenly trying to mash it
into something it's not designed for...
What I'm looking for is a way to catalog a folder i've inherited which
is effectively just a dump of a ton of vector/raster files in a mix of
formats. There's a lot of metadata hidden in there, and I want to
catalog it all so that I can start to get this under control.
I've been playing with Geonetwork and used it to harvest this
metadata, and I'm certainly very impressed with its data
browsing/searching features. But I can't find anyway to have entries
in the Geonetwork catalog linked back to the datasets/files that these
entries were harvested from!
Is this possible in Geonetwork? Ideally I'm looking for a way to
catalog all these flat files + PostGIS tables + various online WMS/WFS
sources (no issue there), and then have some easy way to add them as
layers to a project in QGIS (I can handle that part if it's not
already been done by someone).
Nyall
Hey Nyall
You can create a dataset resource link in records, perhaps that is what
your after?
There are methods to populate GN from data on a server. You either use
crawler apps or you can build a process that genrates the xml the loads via
api or normal import methods. I havent used any crawlers but if you search
the list you should find some references to some.
It would be awesome to be able to use GN to build a qgis project!
Luke
On Friday, 29 July 2016, Nyall Dawson <nyall.dawson@anonymised.com
<javascript:_e(%7B%7D,'cvml','nyall.dawson@anonymised.com');>> wrote:
Nyall
GeoNetwork-users mailing list
*Luke Bassett*
* <lukembassett@anonymised.com>*Melbourne Australia
On 29 July 2016 at 18:11, Luke <coolhandluka@anonymised.com> wrote:
Hey Nyall
You can create a dataset resource link in records, perhaps that is what your
after?
You're referring to
http://www.geonetwork-opensource.org/manuals/trunk/fra/users/user-guide/associating-resources/linking-online-resources.html#linking-a-database-table-or-a-gis-file-on-the-network,
right?
Is there anyway to populate this using the built-in harvester? And if
not, I'm curious as to why. Is it outside the scope of this project?
Or would a patchset be welcome?
Nyall
Luke
On Friday, 29 July 2016, Nyall Dawson <nyall.dawson@anonymised.com> wrote:
Nyall
Luke Bassett
Melbourne Australia
Hey
​ Nyall​
No it doesn't crawl itself.
​If there was an in built crawler it would need to handle generating
metadata in different metadata profiles.
I haven't seen how the existing crawlers work but with my scripts to
generate metadata XML they just populate a XML template using 19115 / 19139
structure and content. This template is mostly pre-populated with regional
information and contact / custodian details. The rest of the fields are
then generated from a spreadsheet I have the client populate. This fills in
all the blanks and makes the metadata XML meet the min requirements of the
profile.
If i were going to just search datasets in a drive or database you would
need to do a lot more data entry to get a record that is useful and meets
minimum requirements of the profile. A metadata record only populated with
File path / name, extent, modified date is not very useful.
I guess you would need to fill in the gaps somehow, perhaps an in build
crawler could do similar to my workflow and allow the user prefill a
template and then crawl and build records based on the template. The user
would be able to map which elements are popualted by the crawl.
​Perhaps others will chime in.​
> Hey Nyall
your
> after?
You're referring to
right?
via
search
Nyall
> Luke
>> Hi all,
>> Cheers,
>> Nyall
>> _______________________________________________
> Luke Bassett
> Melbourne Australia
Hi, for example Talend spatial metadata crawler use OGR to grab information
from DB tables, vector files, raster files, Qgis maps, ... and build XML
records based on a template
https://github.com/talend-spatial/workspace-metadata-crawler. It can then
load those records in GeoNetwork or update existing records. There is also
some monitoring jobs to keep catalog and data store in synch. eg. to detect
if files were removed/moved from the filesystem and send notification by
email, ... That may help.
Francois
2016-08-01 11:54 GMT+02:00 Luke <coolhandluka@anonymised.com>:
Hey
​ Nyall​
profile.
> > Hey Nyall
> your
> > after?
> You're referring to
> right?
> via
> search
> Cheers,
> Nyall
> > Luke
> >> Hi all,
> >> Cheers,
> >> Nyall
> > Luke Bassett
> > Melbourne Australia
On 1 August 2016 at 19:54, Luke <coolhandluka@anonymised.com> wrote:
Hey
Nyall
If there was an in built crawler it would need to handle generating metadata
I'm a little confused - isn't this exactly what the inbuilt file
system harvester [1] is? Or am I confusing the harvester with
something it isn't?
Nyall
1. http://www.geonetwork-opensource.org/manuals/trunk/eng/users/user-guide/harvesting/harvesting-filesystem.html
information and contact / custodian details. The rest of the fields are then
generated from a spreadsheet I have the client populate. This fills in all
profile.
> Hey Nyall
> your
> after?
You're referring to
right?
> via
> search
Nyall
> Luke
>> Hi all,
>> Cheers,
>> Nyall
> Luke Bassett
> Melbourne Australia
On 1 August 2016 at 20:01, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
Sounds great! I'll definitely be investigating this option.
Nyall
Francois
Hey
Nyall
19139
in
profile.
> > Hey Nyall
> > what
> your
> > after?
> You're referring to
> right?
> > loads
> via
> search
> Cheers,
> Nyall
> > Luke
> >> Hi all,
> >> which
> >> of
> >> these
> >> WMS/WFS
> >> Cheers,
> >> Nyall
> > Luke Bassett
> > Melbourne Australia
2016-08-01 12:07 GMT+02:00 Nyall Dawson <nyall.dawson@anonymised.com>:
> Hey
> Nyall
metadata
something it isn't?
Local Filesystem Harvester "will harvest metadata as XML files", it does
not deal with data (but that could be a good improvement).
Francois
Nyall
1.
19139
regional
then
all
> profile.
with
>> > Hey Nyall
what
>> > your
>> > after?
>> You're referring to
>> right?
loads
>> > via
>> > search
>> Cheers,
>> Nyall
>> > Luke
>> >> Hi all,
which
of
these
WMS/WFS
>> >> Cheers,
>> >> Nyall
>> > Luke Bassett
>> > Melbourne Australia
