I put geonetwork as the root folder in tomcat so I can access it via
http://localhost:8080 or http://localhost:8080/srv/en/main\.home
When I open this site it shows the following error:
Error Raised exception while starting appl handler. Skipped.
Exception java.lang.StringIndexOutOfBoundsException: String index out of
range: -1
Message String index out of range: -1
Handler org.fao.geonet.Geonetwork
http://osgeo-org.1560.n6.nabble.com/file/n4345610/Untitled.png
Is it possible to solve this error is does geonetwork require the folder in
the address:
http://localhost:8080/geonetwork
regards, Chris
View this message in context: http://osgeo-org.1560.n6.nabble.com/geonetwork-as-tomcat-root-directory-tp4345610p4345610.html
Ok,
I solved the problem by creating an html as the root of tomcat to redirect
automatically to the geonetwork webapp:
<meta HTTP-EQUIV="REFRESH" content="0;
url=http://comet.gutech.edu.om/comet">
the site is now online>> http://comet.gutech.edu.om
It uses the new widget GUI that I have extended with a toolbar for functions
that are only available with the old GUI.
Sorry that the DB is still empty. metadata creation will start during this
week.
now there are just three more questions:
1. how do I change the data dir to a folder that is outside the geonetwork
folder.
I found the datadir option in the config.xml but that only seems to work
for relative paths inside the GN root folder.
2. Same for geoserver... is there also an xml where I can specify the data
dir?
3. Since the DB is still empty and I need make a workshop next week I was
wondering if there are any public nodes I can use to harvest some global
data. Do you know any pages that offer public harvesting access to their DB?
especially USGS would be interesting.
thanks, Chris
View this message in context: http://osgeo-org.1560.n6.nabble.com/geonetwork-as-tomcat-root-directory-tp4345610p4346028.html
