[GeoNetwork-users] Geonetwork - bad script - create-db-postgis.sql
Hi folks,
I have the same problem like Alain (2011-02-23 16:23) or like Robert (2011-02-25 19:52):
Re: [GeoNetwork-users] gast: database setup: INSERT error
https://sourceforge.net/mailarchive/message.php?msg_id=27106327
https://sourceforge.net/mailarchive/message.php?msg_id=27118789
I proceeded exactly according to the instructions:
http://geonetwork-opensource.org/_static/foss4g2010/FOSS4G_Mastering_Advanced_GeoNetwork.pdf
The problem comes up on page 17 with the following script:
Is there a new script that works?
Had anybody the same problem and could resolve it?
Can anybody help me with this problem?
I wish you a nice weekend.
Looking forward to a response from you
Regards Maik
E-Mail: maik.wannink@anonymised.com
Hi Maik
There was a bug in that script that was fixed after the GeoNetwork release.
You can download from
https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/branches/2.6.x/web/src/main/webapp/WEB-INF/classes/setup/sql/create/create-db-postgis.sql
or just replace in your script the actual table Languages definition by
this:
CREATE TABLE Languages
    id varchar(5),
    name varchar(32) not null,
    isocode varchar(3) not null,
    primary key(id)
Jose García
On Fri, Mar 4, 2011 at 12:43 PM, Maik Wannink <
maik.wannink@anonymised.com> wrote:
Hi folks,
(2011-02-25 19:52):
Regards Maik
What You Don't Know About Data Connectivity CAN Hurt You
This paper provides an overview of data connectivity, details
its effect on application quality, and explores various alternative
solutions. http://p.sf.net/sfu/progress-d2d
GeoNetwork-users mailing list
Hi
Also seem the field *isocode* ended by error in *settings* table in
that *create-db-postgis.sql
*script. You should remove that column from *settings* table.
Jose García
On Fri, Mar 4, 2011 at 1:52 PM, jose garcia <josegar74@anonymised.com> wrote:
Hi Maik
this:
    id varchar(5),
    primary key(id)
Jose García
Hi folks,
(2011-02-25 19:52):
Regards Maik
