Dear All
I am a new bee working on Geonetwork(2.8.0-0). I had customised Geonetwork
for cataloging few spatial datasets.
The Geon/w application is working fine on localhost,but when I am trying to
access this from different system by typing the URL
like http://l192.168.14.45:8080/geonetwork/srv/eng/main.home<http://localhost:8080/geonetwork/srv/eng/main.home>
instead
of
http://localhost:8080/geonetwork/srv/eng/main.home I am unable to get the
Interactive map and world map on search side.
I google alot and found that I have to change the jetty.xml by adding <Set
name="host"><Property name="jetty.host" default="192.168.14.45"/></Set> or
0.0.0.0.
I tried all the options but unable to get out of this problem.
Can any body help me to solve this problem.
Thanks in advance for the help.
With Regds
Rishi
Hi Rishi
The map layers configuration is done in this file: WEB-INF/config-gui.xml,
please check to update localhost to your server IP in these sections:
mapViewer and mapSearch.
Jose García
On Thu, Apr 4, 2013 at 3:25 PM, Rishi Kapoor Pandey <
rishikapoorpandey@anonymised.com> wrote:
Dear All
instead
of
0.0.0.0.
With Regds
Rishi
Minimize network downtime and maximize team effectiveness.
Reduce network management and security costs.Learn how to hire
the most talented Cisco Certified professionals. Visit the
Employer Resources Portal
http://www.cisco.com/web/learning/employer_resources/index.html
GeoNetwork-users mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net for details.
_________________________
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/>
