[GeoNetwork-users] Geonetwork / CSW 2.0
I downloaded the last beta version of GN and I would like to try to use
the CSW 2.0 implementation with a connection betwwen GN and the
commercial product IONIC Catalog (to test ! ).
I studied the doc but I don't see how GN implements the CSW 2.0
standards. Some questions...
The CSW 2.0 describes these operations :
  - getCapabilities
  - describeRecord
  - getDomain
  - getRecords
  - getRecordByID
  - Transaction
  - Harvest
Does GN implement all ? Which binding is available (KVP, SOAP,....)
If I remember the last workshop, you decide to use the ISO 19115/19119
API profile. Do I mean that you transform each metadata file in GN in a
valide XML file according profile ? Do you integrate the 19119 schema ?
After, I will be able to start a "testbed" !
Pierre LAGARDE
Le contenu de ce m?l et de ses pi?ces jointes est destin? ? l'usage exclusif du
(des) destinataire(s) express?ment d?sign?(s) comme tel(s). En cas de r?ception de ce
m?l par erreur, le signaler ? son exp?diteur et ne pas en divulguer le contenu.
L'absence de virus a ?t? v?rifi? ? l'?mission du message. Il convient n?anmoins de
v?rifier l'absence de contamination ? sa r?ception.
The contents of this email and any attachments are confidential. They are intended for
the named recipient(s) only. If you have received this email in error please notify the
system manager or the sender immediately and do not disclose the contents to
anyone or make copies. eSafe scanned this email for viruses, vandals and malicious
content.
Hi Pierre,
GN has passed the CITE tests against the base CSW/2.0.1 spec.
This means that it can be queried to obtain metadata in the dublin
core format.
The ISO 19115/19119 profile is implemented but it is based on
an old draft which seems pretty different from the latest one.
I don't expect interoperability using the ISO profile.
The implemented operations are the mandatory ones:
   - getCapabilities
   - describeRecord
   - getRecords
   - getRecordByID
and you can use GET/POST/SOAP bindings.
Metadata affected by CSW queries are those in dc and iso19115/139
format. There are some stylesheets that convert these metadata
into the proper dc output format.
  - getCapabilities
  - describeRecord
  - getDomain
  - getRecords
  - getRecordByID
  - Transaction
  - Harvest
Pierre LAGARDE
