hi,
thanks for your feedback.
The always-indexing-on-startup is a bug introduced with GN 2.4. It has been
fixed too, quick to apply :
http://n2.nabble.com/SF.net-SVN%3A-geonetwork%3A-4929--trunk-src-org-fao-geonet-kernel-search--SearchManager.java-td3457348.html#a3457348
Juan Carlos, you're right, I also find indexing seems very much slower than
it used to be. Maybe because now there is both a "non-spatial" and a
"spatial" index ? In any case, maybe shoving it off into its own thread may
be a workeable solution to that.
Kind regards
Heikki Doeleman
2009/8/17 Juan Carlos Méndez <juanmendez@anonymised.com>
I get the same issue with Geonetwork 2.4
Additionaly it takes a really long time to re-index the whole data set (11
hours for 53000 metadata records)
Is there any way to improve re-indexing speed?
(I had to modify geonetwork's source to allow user access during indexing
on start-up. It uses a new thread for re-indexing)---------- Forwarded message ----------
To: <tropicano@anonymised.com>
Date: Mon, 17 Aug 2009 09:26:04 +1000
Subject: Re: [GeoNetwork-devel] Geonetwork 2.4 re-indexing every time
onstart-up
Heikki,I get the same thing, on restarting the system my geonetwork.log says:
2009-08-17 09:13:25,453 ERROR [geonetwork.search] - Rebuilding lucene
indexI am running GN2.4 built from the installer using Java 1.5.0_14 and Win XP
SP3.Andrew Walsh
Juan Carlos Méndez
http://gkudos.com/------------------------------------------------------------------------------
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus
on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
GeoNetwork-devel mailing list
