[GeoNetwork-users] [GeoNetwork-devel] Geonetwork 2.8 Branch Widgets Interface
Francois,
Thanks . I was able to build using widgets option and when I access the link http://localhost:8080/geonetwork/apps/
I see links like Search Edit etc and when I click on Edit It says not found and Search etc I can see. Is Edit functionality part of this widget interface?
Also is there a way to integrated these widgets interface directly into mainstream geonetwork instead of using /apps etc? Please let me know. Thanks
Regards
Kumaran
Hello Kumaran, usually the widgets interface is available in the apps
folder (ie. http://localhost:8080/geonetwork/apps/). For the configuration
check the WEB-INF/config-gui.xml file [1]. To build the WAR with the
widgets use mvn with the -Pwidgets profile option [2]. Cheers. Francois [1] http://trac.osgeo.org/geonetwork/wiki/proposals/WidgetsBasedGui#Configuration [2] http://osgeo-org.1560.n6.nabble.com/Building-widget-based-UI-td3875582.html 2013/1/3 Kumaran Narayanaswamy <kumaran.narayanaswamy@anonymised.com> > Hello,
We downloaded the geonetwork code from 2.8 branch and built the war file
and we would like to enable the Widgets ExtJS based interface.Is this
Interface available for all screens especially for the Metadata Editor
screen.
After deploying we see the default interface.If widget interface is
available can anyone please help how to enable that? Thanks.
Regards
Kumaran
Kumaran,
2013/1/4 Kumaran Narayanaswamy <kumaran.narayanaswamy@anonymised.com>
Francois,
interface?
Yep the metadata editor is part of the widget you could use the tab layout
http://localhost:8080/geonetwork/apps/tabsearch
or the other one
http://localhost:8080/geonetwork/apps/search
Once you made the config in config-gui.xml then it will use the widget as
the default UI for your catalog and all links should drive you to the
widgets UI instead of the main.home page.
HTH.
Francois
Regards
Kumaran
[1]
http://trac.osgeo.org/geonetwork/wiki/proposals/WidgetsBasedGui#Configuration[2]
http://osgeo-org.1560.n6.nabble.com/Building-widget-based-UI-td3875582.html2013/1/3
Hello,
> screen.
> Regards
> Kumaran
Master HTML5, CSS3, ASP.NET, MVC, AJAX, Knockout.js, Web API and
much more. Get web development skills now with LearnDevNow -
350+ hours of step-by-step video tutorials by Microsoft MVPs and experts.
SALE $99.99 this month only -- learn more at:
http://p.sf.net/sfu/learnmore_122812
GeoNetwork-users mailing list
